Today I received a "free" Pioneer Elite VSX-94THX receiver
pumpkinman
This is a goggle image
This receiver had a MSRP of $1800
What it didn't come with was a remote control or a manual
Since I know nothing about home theater I was wondering if this is considered a decent unit ?? Should I search out a remote ??
P-man
Because I am The Pumpkinking
Manuel can be found online in 30 seconds, as for the remote I'm quite certain you can get one easy enough on eBay or strait from pioneer. And free is fantastic congrats.
Cheers -
Can't beat free with a stick. You have a use for it though ? Won't give you the newer surround sound codecs but if you don't do movies then it isn't a worry.HT SYSTEM-
lsi 9's -
Free is a good price. Good pickup!
https://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/477134684VSX92TXHOperatingInstructions0807.pdf
Yep, she was a powerhouse back when, but with outdated software the use for HT is somewhat limited. Might be good driving a second system where all the bells and whistles aren't needed. Has a decent dac in it, a good amp section, and free....gotta use it for something.HT SYSTEM-
lsi 9's -
Can't beat that price..
Wow are you guys jokin or what? The only codexes it doesn't do are atmos and 4K pass through. LOTS of us are into HT and don't have either or those.
If u don't want the avr I will happily take it off ur handsLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
As for a remote just get an older cheaper refurb harmony off fleabay. It'll do everything u need except maybe zone 2...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@rooftop59
Thanks much I'm afraid I wasn't understanding Tony's replies. As I stated I know less than nothing about AVR's / surround sound. I contacted a friend who told me the same thing as to the remote. I'm looking at the Logitech Harmony 650 on Amazon at $55. Upside to this vs. the original remote is it will do the my Blu-ray and TV.
Congrats. Heck while your waiting for remote use it for a workout
its a heavy beast Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Yea that receiver looks awesome. The only thing that I am interested in that it wouldn't do is stream music. But for that price you can buy something else...
Yes that remote is fine. Cheaper on eBay though...I think I see returbs for 38 shipped...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Thanks I'll check eBay as well
P-man
Here ya go man: http://www.ebay.com/itm/111249083612?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:ITLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Why "free" instead of free? You traded something in return?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I've got the 92 on the bedroom system. The original remote is nothing to write home about, it's too busy and laid out poorly. The Harmony 650 is much better.
I've got the manual in PDF if you can't find it online.
Did you get the calibration mic? -
Haha I don't even know what a calibration mic is. So the answer is no.
Thank you for taking the time to search it out for me
Bill
Well, you need the MIC or you will never know how good it is.
Some people set these guys up by hand but not me. -
rednedtugent wrote: »Well, you need the MIC or you will never know how good it is.
Thanks Red I looked it up and it not much moola.
It's a fantastic receiver and I really loved it back in the day. CoolDan
Check with your cable/sat provider as their remotes are universal and will usually work the common av equipment.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
michael1947 wrote: »Check with your cable/sat provider as their remotes are universal and will usually work the common av equipment.
True for the most basic functions but you'll be hard pressed to emulate all of these buttons with the typical remote provided by your cable/sat provider.
This line of VSX is very good for HT, will support 7.1 and play the newer codecs as PCM in each channel. I had the 81 model of this series and passed it on to my oldest when he moved out. The calibration mic helps when setting up a HT system and helps setup the Surround Back speakers If your not sure about it send it over to me, I have the remote.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
Wrong thread
Very nice score, P'man!Power Amps: Luxman M-02, Luxman M-2000, Luxman M-300
Preamps: Luxman CX-100, Luxman C-1010, Luxman C-120A
Speakers: Polk Audio SDA-2B's (no mods...yet), Klipsch KG4's (Crites Crossovers and Titanium Tweeters), Genesis 1's
Digital Front End: Marantz CD6005, Denon DVD-2200, Fiio X5 II
Headphones: Sennheiser RS180, Sennheiser HDR170 w/Fiio E12 Montblanc (home). Sennheiser HD449 w/Fiio E12 Montblanc (portable)
EQ: SAE 180 Parametric -
Don't nothin' sound as good as a free receiver!
Congrats and enjoy!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
