Ground loop issue and imaging...
nooshinjohn
I reintroduced the Pass labs to the mix tonight after I set the Xono to ten settings desired by the C/A Titanium. I have triple checked the settings on the Xono, and they are correct for low output MC. The previous settings had no hum issues. It was set to MM, and the Dynavector was happy there. All connections have been checked and checked again. I use balanced connectors from the Xono to the X1, and a tol shelf Analysis phono cable...
More perplaxing is the image has shifted to the right, and I have to compensate by adjusting the balance to the left a couple points. This has never been an issue before.
I have also redid the connections on the SDA's so the phasing is once again correct. The above is only when listening to the turntable. All other components operate flawlessly with no problems at all.
Any ideas guys?
Any ideas guys?
Crazy thought....the last setup was off and the new one is revealing the actual recording?
With the balance set, the sound is stunning....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Ground lift? For the hum.
I am thinking the troubles are inside the Xono. There are what look like adjustment pots that could be off, and the ground loop did not start until I flipped the switch to MC from MM... I think I will be sending it out for service whe I get the motor for the table tweaked.
My god this sounds superb... Charlie Rich is alive and in the room.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Sounds like you have reached your "almost" pinnacle in the journey. It's been a treat to see you flourish from a pair of 1C (IIRC) to building your own tube space heaters to this.
A tip o the hat, John.
I had monitor 50's, a Yamaha RXv2090, no turntable, and no clue. One thing for sure is I was a putz of epic proportions. The other thing I know is I would have a much bigger bank account if I had been banned way back when...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Yep. The 50's... To that which you have now. Carry on.
And I got put in time out a couple of times myself.
John, hate to ask such a silly question given the cost of your new toy, but are you sure the cartridge is shielded ? I'm more inclined to think the hum is coming from the cartridge or how it's grounded than the phono itself.
Of course you can always go old school and run a wire from the phono to another piece to see if that helps.HT SYSTEM-
lsi 9's -
The balance issues may be related to cartridge alignment, or the dip switches in the phono pre. The ground issues may prove more problematic.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Probably shoot Pass Labs an email since it's their phono pre."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
I talked to them this morning. I an going to do some troubleshooting, but they also suggested I look to the cartridge setup. I am going to pop the top off the Pass and reset the dip switches, and deoxit them a bit too.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Could the image balance issue be related to antiskate?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
John, not familiar with your TT but mine has 2 ground wires. 1 from the center of the spindle and 1 with the rca's. I had both the grounds hooked to my pre and had also a hum. So I took the one from the center of the spindle and hooked it to my avr and the hum went away.
The hum started when I went from a MM cartridge to a MC.Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
I went from high output MC to low output. I am going to run another ground from my phono pre to the power conditioner and see what that does.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Yeah, mine is a low output too, maybe that has something to do with it. Hope that works for ya!Anaheim Hills CA,
Are the connections going to the right place where they plug into the cartridge?Vinyl, the final frontier...
Ok... Did what Pass recommended and popped the top again. Made a tweak and the imaging is resolved, I also put things back on the MM setting and left everything else the same, the 60htz hum also vanished. Back to the MC and it returns. This eliminates the cartridge, cables, and everything else but the MC side of the preamp. Looks like a trip to Poppa's workshop is in order.
*** Edit.... I found the hum is still there, just nowhere as close to noticeable on the MM side. I guess that tends to put some focus on the cartridge, given that is the only variable the has been changed.Post edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
John I did what Rich @SCompRacer did by using a SUT (step up transformer) with my high MC cartridge and using my phono amp set to MM and it works great! works even better for Low MC cartridges!
Got my from Parks audio and Shannon ask about my set up and then gave me the correct loading's.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I will be looking into this. Pass suggested this as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Same here. Love the Budgie SUT. Does wonders for my AT and DL-103r carts. Has a ground lift that might be useful in your case?John I did what Rich @SCompRacer did by using a SUT (step up transformer) with my high MC cartridge and using my phono amp set to MM and it works great! works even better for Low MC cartridges!
Got my from Parks audio and Shannon ask about my set up and then gave me the correct loading's.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Life used to be so simple
Hey Ron... as our good friend Lightman would say.... UP YERS!!!
As I'm sure that will offend someone, I reported it.
President of Club Polk -
That's, Sir Snitch to you.
Aye cap'n!
