Refreshing Black Veneer on a CS1000p
Inspector 24
I've used this method on a few speakers before with good results. This guy had a few little dings and scratches in it, making it look a little older than it performed. Here's how I went about touching up the veneer of my black CS1000p.
First cleaning it with a light solution of Windex and water to get little bits of dirt/smudges off it, then allowing it to dry thoroughly so the next steps will be more effective.
Then, using a Minwax Wood Finish Stain Marker in Ebony I stain underlying wood a nice black, using a healthy amount on the bigger chip.
Then to blacken up the rest of the veneer and cover up other tiny tiny spots I stripe up the sides, then rub with a paper towel to distribute the stain. You can see the before/after in the half-done top.
I rub it out in 3-4 steps until the towel is near clean, then set it aside to dry for a couple days.
End result, a nicely refreshed blackness and hidden scratches.
Up
LSi15 LSiC - RX-V3000
Down
Sim2 D60 - Dragonfly 106" Panny 500
Down
That does look nice. Great job. As heavy as that thing is - i can understand why it may have scratches here n there. Thanks for the tipRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Looking great.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Great tip! Thank you for sharing and excellent work!SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
Yes, it is a heavy beast indeed. I've done this to a dozen or so RTx Series speakers so far, works great every time, always makes them look so pretty and new.
Sounds awesome too. Great speaker for running Mono...In fact I bet two of them stood on end would make pretty great left and right channels!Up
Down
Sim2 D60 - Dragonfly 106" Panny 500 -
That looks great! I'm going to try it on one of my SRT satellites tonight.
