FS: McCormack DNA-1 Deluxe Amplifier
Chicken! -
pfft!!!
You would not say that to my face mr. lightman! lolAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
Ok guys, I posted the link to where I bought my first McCormack amp, DNA 1 below.
The review of this one is basically spelled out there. Simply more of the same.
Bigger sound stage, better detail and separation, bass,,,etc.
I am loving it, no regrets on either McCormack amp. If you haven't tried one, you should.
I thank @tonyb for steering me toward them.
http://forum.polkaudio.com/discussion/167306/ic-mccormack-dna-1/p3Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Glad to hear you're happy. Hope it gives you years of enjoyment.
Cheers!Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Cheers!
Thank you, I am sure it will.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Pulled the trigger and ordered one of these:
http://www.cullencable.com/index.php/products/power-cables/crossover-series
Hope the link works.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Very interesting.. A buddy and I are building a cable that is almost identical, except we are using 10 awg. I also ordered sonar quest plugs that haven't showed up yet. We barely built ours cheaper that those, although I did two at 3 meters.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
You guys sure you want to use silver in a power cable to match up with the McCormack ? Just my opinion, but silver doesn't seem to have the soundstaging that copper brings, and which the McCormacks are fairly good at.HT SYSTEM-
lsi 9's -
If you read the reviews one of the great ones is a guy using a McCormack?? Won't know till I try it.
Going to take about a week to ship, he is very busy.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Below is the review I referred to:
Quality Power Cable for cheap... “Tried out a Cullen Cable Crossover Power Cable on my McCOrmack DNA-500 and it meets or exceeds the job done by cables costing way more. So, if you had the bug to try upgrading power cables but not willing to gamble the farm, might be worth a try. Will share my observations: Have both a Synergistic MC with MPC and a Kimber Palladian PK 10, both pretty to very expensive cables with different strengths that I have used with the McCormack. After a brief survey of musical styles (Dave Holland/Pepe Habichuela, Metheny/Scofield, Tedeschi/Trucks and Peter Case stuff), the Crossover has equal or more detail than the Kimber but with better focus and I get better balance and response at the frequency extremes than with the S MC. After a bunch of back and forth, had settled the S MC because it was fuller in the mids where the music's heart is (voices, sax, piano, guitar) and more 3D presentation and gave up deeper bass and extended highs of the Kimber, which seemed a bit hollow in the middle. Crossover seems to retain the rich middle and add the high and low end extension, have better focus and clarity than either of the above resulting in a better 3D/spatial presentation of the instruments in the recording space. This is with only 24 hours on the cable, others have said a 100 hours does some good. Cost was @$175 versus the other two at like $500 and $1250.
No, I don't do double blind, I have good ears. I have no relationship with Cullen other than customer satisfaction.
Best way to connect Cullen Cables is on Audiogon, his new site is a WIP.”Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The power cable came in today. Got it plugged in and playing. Initial thoughts are good, hearing some details I haven't noticed before.
Will let it run a while and see how it goes.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
