sub woofer into another device
leftwinger57
Once I re wired my Klipsch sub w/ double braided coax and the right fittings the thing never sounded so good. Well so good I questioned whether my 2Bs were lacking in bass and most say no just hearing better placement. Now I use only 1 of the red/white female ports to my Yamaha RX-V-665sbwofer input. If I got a preamp w/ a sub out could I use the other port and bolster my 2 chll doing it that way. I also have some kind of Monster Cable Y-connector for subs I think for adding another to the mix.
You can Y into another sub, as long as you have headroom in your sub settings to increase a little, since the split will decrease voltage going to the first sub in half. Adding a identical sub doesn't add volume due to that voltage decrease unless you have more volume available in you settings.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
