New Polk owner of pair of 5JRs & 11t FREE from CL needs help
OK, this is my first set of Polks so I need a bit of help. As far as the monitor 11ts, the passive radiators look like there are no leaks, the 2 midranges work fine and the SL2000 is definitely harsh sounding so I'll probably mod that with the TL & crossover. The cabs are in so-so condition and I will use Howard's RAF to help with that. Grills cloth a bit loose and some picks, only one of the 2 has the Polk label.
The 5Jr cabs are in similar condition, though one needs a bit of work on the corners. Both have loose grill cloth and are missing the Polk label. One of the pair sounds nice (again, the SL2000 needs to go) and no apparent leaks for the passive radiator. The other has a frozen MW6502 driver.
So here are the questions:
- The 5Jr label has 5JR on it (SN30591) and the bad driver has date of July 22 1987. The driver is labeled as 5JR+. So what version of 5JR do I have?
- As far as replacing the 6502, where is the best place to get an original replacement?
- I probably will get the Polk emblems as well, it this just and ebay item?
In advance, thanks!
  • TCK
    TCK Posts: 231
    These are 5 jr+ ,they have the passive radiator
    Best place for original drivers & Polk emblems is eBay.
    - L200 Legends (Black Oak)
    - SDA 2B (1989, Oak Tops, 194s, Spikes)
    - Monitor 7B (1982 Peerless, Sonicaps, Mills, Binding Posts)
    - (2) SVS SB12-NSD (Flat Black)
    - SVS SB 3000 (Gloss Black)
    - CSi A6 Center (Cherry)
    - Pioneer SC-1222K (7.1 AVR)
    - Marantz MM 7055 (5 Ch Amp)
    - Pioneer PD-D6 SACD Player
    - Marantz NR1403 (5.2 AVR)
    - Sony UBP-X800M2 (4k Blu-ray)
    - Sony UBP-X1100ES (4K Blu-ray)
    - Adcom GFA 555 Amp
    - Monitor 5 (194s, Side Surrounds)
    - Monitor 5Jr+ (194s) {Storage}
    - LG OLED65CXPUA (4K OLED TV)
    - LG 55UN7300PUF (4K HD TV)
    - RT35i (Cherry)
    - (2 Pair) RT25i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
    - F/Xi A4 (Rear Surrounds)
    - RT25 (Rear Surrounds) {Storage}
    - Audioquest Interconnects
    - Blu-Jean Speaker Cables & Interconnects
    " But boy do I remember the strain of her refrain " LG
  • boston1450
    boston1450 Posts: 7,758
    Call Polk. They should have woofer & tell them your a forum member & they will give you a discount. Welcome to Polk Forumucd3lqh89s04.jpeg
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • TCK
    TCK Posts: 231
    It sounds like he wants an original driver. Polk CS will not have original drivers. They do sell replacement drivers though. It depends how you read his question.
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • boston1450
    edited April 2016
    Ebay & other sites used. Hang around here a bit & maybe someone will have a spare not being used.... New ones from Polk if they have them i dont think you'll notice the difference.
    Post edited by boston1450 on
    Randy-Maine
    by David WMG
  • pkquat
    pkquat Posts: 748
    AFAIK the MW's for the 5jr and 5jr+ with the SL2000 tweeter were the same, the 6502. I think one of my 5Jr's has both the 5jr box checked and a 5jr+ stamp. The 6502 was also used in the 4A if you plan on searching ebay. I am not sure about the Series 2. I think that uses an equivalent MW and is available from Polk CS.
  • codycatalist
    codycatalist Posts: 2,661
    With the TL mod comes the RDO198 which like you mentioned will require cross over changes and might as well upgrade them. They do make a silk dome RDO194 upgrade that is a drop in replacement for the SL2000 tweeter. I believe the 198 is slightly larger so modifications to the cabinet might be needed.
    If you can't do the cross over yourself Id advise you to check out westmassguy or dhs speaker repair.
  • agfrost
    agfrost Posts: 2,483
    Make a plan before ordering tweeters. The RD0-198 (as Cody said) requires changes to the crossover, namely one of the inductors has a different rating between the two models.
    If you decide to leave as 11T's, the RD0-194 is for you. The 198 and 194 both have identical mounting needs, so no cabinet modification needed for either choice. (The Peerless and SL1000 tweeters are the ones with different form factor).
    Have fun and good luck. I modded a pair of RTA11TL some years back; they're still kicking it at my brother's house.
    Jay
  • pkquat
    pkquat Posts: 748
    The 5jr's only require a single capacitor change to use the 198 vs the 194, so it is a very simple upgrade. The 198 requires 13.5µF and the 194 requires 12µF. The schematics for the speakers can be found as one of the "Announcements" at the top of Vintage Speaker section.
    Here is the link:
    forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-more-all-models-except-sda
    As mentioned Westmassguy is the guy to go to if you don't feel up to the task of upgrading the crossovers.
  • subkron
    subkron Posts: 82
    Thanks to all responses. I have no problem doing the crossover mod and I've even looked at fixing the 6502. Doesn't look too bad, save a few bucks but need to decide if it is worth my time.
    Thanks again...
  • lawdogg
    lawdogg Posts: 469
    Congrats on a heck of a score!
    Does the 11t have veneer on it or is it vinyl? RAF doesn't really work on vinyl .... :blush:
    For the 6502, if you want to do an even trade, your frozen 6502 for a re-set and glued 6502, let me know. I have a re-setting jig and I'm trying to get a trade-in program going to help everyone out who has shifted magnets.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • codycatalist
    lawdogg wrote: »
    Generous offer and a great idea. I like how you think.
  • subkron
    subkron Posts: 82
    lawdogg wrote: »
    That does sound like a good idea, I messaged you about the even trade.
  • skrol
    skrol Posts: 3,483
    lawdog
    I think I have a frozen 6502 collecting dust. If you are interested, I could donate it to the cause.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • codycatalist
    @lawdogg I have a frozen MW6510 I could donate as well. No use for it here, just missing the dust cap.
    pitdogg2 Posts: 27,597
    No modifications are needed to the cabinet same size as the SL2000 BUT they do have two different size quick connects to discourage the use in speaker with SL2000. You will need to cut and crimp a new connector no biggie. There are going to need to be modifications to the XO for sure to be able to use the RDO198. FWIW the RDO 194 is leaps better than the SL2000 and is drop in replacement.
