mini-monitors / finally scored!
After years of searching and waiting patiently for the right opportunity, I scored a pair of MM off e-bay last night. I'm curious to know if anyone is familiar with the mids on this pair. They don't look stock nor do they look like an oem replacement. At this point I don't care!~ I'll figure out how to handle.cczgy964cdsn.jpg
Welcome!
    Those mids are not original. Polk used 4.5" CTS drivers, with foam surrounds. Essentially the same driver used in the Series I & II 901s.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    http://www.ebay.com/itm/272011745877?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    link to a sale on ebay with the correct or at least closer than what you have mid.
    I've got a pair and some spare cabinets and rough passives as well as crossovers in my closet. I was watching the same item because I have a saved search in ebay for the mini monitors. They are rare and hard to find. Based on what you paid, you obviously wanted a pair badly :). I'm still looking for a decent set of grills. Hope you enjoy them.
    A nice pair went on eBay about a month and half ago. I posted a WTB ad with photos in the classified section with what looks like the original midbass drivers.
    The original CTS drivers aren't terribly hard to find -- they're also very nice midrange/extended range drivers in their own right (and, of course, IMNSHO).
    Thanks all. This information is truly appreciated. I shocked myself at the price point but I was waiting for a while, and cut my take-out budget for the month!
    I always wanted a pair of those.
    The woofer look like they're quality, polyprop's with butl rubber surrounds.
    How do they sound ?
    edited April 2016
    Elitt- If you don't mind me asking= How much did you pay and hows their physical condition? And does anyone know what their original MSRP was?
    I paid about 140 shipping included. The cabinets are in great shape. Another pair just went for about $18 but had a couple holes in each. Oh well...sippin' n' clickin' last night. What can you do? Adjust the household budget and move on.
    They're cool to have just because their rarity. Same with the Peerless Monitor 4's, they don't pop up too often either.
    Are you going to replace the woofers?
    Enjoy those speakers, I bet they sound better than you'd think just by looking at them.
    afterburnt wrote: »
    Village Idiot of Club Polk
    Nightfall wrote: »
    Thanks man. I'm going to listen to them and figure it out. If someone knew what they were doing with those mids then I'll leave them as they are.
    I'll report back here. The plan is to use them as monitors for my desktop at work unless the magnets are too strong.
    Man those mini monitors are beautiful! What are the dimensions?
    elitt wrote: »
    You have a CRT monitor?
    afterburnt wrote: »
    In case your still curious as to their dimensions- They are: 35.3 [cm] high x 6 "[inches]wide x 12.2 cm deep
    That is awesome, what cool little speakers.
    They arrived and all is well. One of the best eBay packaging jobs I've ever seen. Someone loved these things in their previous life. 1980 and barely any nicks. I'm sure they'd benefit from a recap but for now I still have the sweetest sounding desktop in the office!
    Nightfall wrote: »
    Ha! I do not, but ignorantly I still though there might be interference.
    Update for the holiday weekend. I managed to get the oddball 4 ohm drivers replaced with original mids, and what a difference it made. I lost a little bass but more than made up for it with clarity and imaging etc. etc.
    There is decent bass with a proper source recording. My Cornell Dead Betty Board is soaring at the moment.
    I know people take a lot of heat for investing in the mini monitors, but it sure beats the alternative: listening to the company approved plastic box desktop set-up.
    I'm digging this sound powered by a Sonos connect amp. I'm really curious to hear these suckers through a more musical source. Loving it here this morning. My office mates, not so much!
    I picked up a set of those last year. The cabs. are in decent shape but the mids need new surrounds.The PR's however also use a cloth like material and although there are no holes when held up to the light you can see through them like a pair of pantyhose.
    I also picked up a pair of Acoustic Research AR-4X that uses the same material and exhibits the same condition.My question- is this normal or are they deteriorating to the point where they are likely to come apart when used?
    Mine fail a true push test, but I'm still surprised at the range these little guys put out. Honestly, with the right source, they're boomin'. I wish I had an answer to your question, but it befuddles me.
    @befuddle there is a glue type sealer that is used to recondition cloth surrounds. You can use it on foam surrounds too. I don't remember a brand name but places like simplyspeakers dot com sells their version for about 6 bucks.
    there's probably better/cheaper stuff. You'll have to shop around.
    Carver TX-11b - Carver 4000t - Carver TFM45 x2 - Polk SDA SRS 2 (094 tweets) - RSL CG 8^2 (Howard's XO upgrade + driver upgrade = 350w rms and amazeball toanz)
    Thanks much Soulsurfer I'll look into that
    edited May 2016
    Soulsurfer - Thank you. Have you seen a product that word work to 'restack' or bind together the layers of cardboard that are on top of the metal frame? Do you think the glue sealer you speak of would work for that?
    I plan on showing these MM some cosmetic and internal love as I will probably be staring at them daily for a while.
    elitt wrote: »
    Glad they're in your hands. They're a rare piece of Polk history.
    afterburnt wrote: »
    @elitt I'm not familiar with polk speakers much. I'm a newbie. LOL I just have some general experience with random speakers.
    I'm not sure exactly what you're talking about to be honest. What metal frame and what cardboard do you speak of?
    The outer rim of the drivers and passives appears to be made of layers of paper-ish cardboard. I'm sure that's the right technical term :) They are starting to fray a bit. Not enough to mess with, but I want to know how to handle the fix or repair if they ever start unraveling.
    elitt wrote: »
    It's called a gasket
    edited May 2016
    I may be wrong but what I think elitt is describing is the material glued onto the outside upper facing outer rim of the driver baskets/screw head side [which are also called gaskets although they don't serve a typical gasket function in this regard] if replacements are unavailable,perhaps[and its just a thought] they might be lightly sanded with a 400 or finer to remove the fray and a small amount of black silicone or similar could be used to top them
    Post edited by befuddle on
    befuddle wrote: »
    I may be wrong but what I think elitt is describing is the material glued onto the outside upper facing outer rim of the driver baskets/screw head side [which are also called gaskets although they don't serve a typical gasket function]
    They do serve a function if the driver is rear mounted.
    As usual, westmassguy settles it.
Welcome!
Welcome!
