gimpod's SDA Boards
  • mxgirl75
    mxgirl75 Posts: 15
    Nightfall wrote: »
    There's nothing stopping you from refreshing your crossovers with the original PCB's.
    The other problem is the size of the Polk crossover boards, if I remember right, the new hardware is very tight fit..
    Yamaha RX-A1000
    Rotel RMB-1095
    Polk SDA 2
    Polk Csi6 Center
    Polk FXi8 Rear
    B&W ASW 2500 Sub
  • You need to to talk to Dave!!
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • tonyp063
    tonyp063 Posts: 1,137
    edited April 2016
    ^^^This.
    Dave will assist people who request his help when the want to do it themselves.
    And if you don't think you can do it, he will.
    And he does not do business via the forum.
    A very ethical & honest man. He gave me several options, and why they would work, & at what cost the parts would be versus quality when I asked what I should buy for parts when I redid my M10 crossovers.
    And no't once did he suggest I send them to him to work on.
    Class act. Smart man.
  • TennMan
    TennMan Posts: 1,266
    Dave is a class act. I highly recommend him for information or if you need your crossovers rebuilt.
  • stogie
    stogie Posts: 230
    ^^^^agreed
    Speakers: Polk SDA-SRS xovers rebuilt by David, RDO194's, Dynamat, BH5, glued magnets, new cloth, custom aluminum terminal plates with Cardas posts and Speakon interconnect
    Speaker Cables, Jumpers & Interconnect: DIY Douglas Connection
    Power Amp: Sunfire Architect's Choice Series II
    Preamp: Adcom GFP-750
    SACD/CD: Oppo BDP-95
    Tuner: Sansui TU-717
    TT: Technics SL-MA1
    Phono Pre: Emotiva XPS-1
    Music Server: Mac Mini w/JRiver - iPad w/JRemote
    DAC: Eastern Electric MiniMax Plus
    Other Polks: SDA: 1A, 1C, 2B, CRS+ / Monitor: 10A, 5jr, 4 / RT5
  • PolkieMan
    PolkieMan Posts: 2,446
    The boards because of the extra room makes it so easy.
    tonyp063 wrote: »
    ^^^This.
    pitdogg2 Posts: 27,340
    mxgirl75 wrote: »
    Nightfall wrote: »
    Correct but many of us did it way before the new boards came out. You will have to get creative in some ways and many have just run wires to the board for caps too big to fit and place the cap off to the side or the bottom of the cabinet. It is not that difficult as to say WOW I can't do it because
  • Gunther16
    Gunther16 Posts: 243
    David's the go to man!!!!!!!
    F1nut Posts: 52,009
    Damn straight!
  • Nightfall
    Nightfall Posts: 10,083
    Well, if you have soldering skills. I've never even touched a soldering iron. :#
    afterburnt wrote: »
    Village Idiot of Club Polk
    Nightfall wrote: »
    Neither had I, but gee whiz get some old speakers and get at it. It's not hard at all after a little practice. You take the caps out and put the same back till you make you look good. If that old speaker plays when your done makes no crackle and pops well then I say go for it.
  • westmassguy
    westmassguy Posts: 6,850
    FYI everyone, I have a good stock of boards. If you need them, get them. This will most likely be Tony's last batch, unless there's significant demand for another run.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • DrumSolo
    DrumSolo Posts: 9
    + Larry's rings
