Parasound New Classic 2250 or Halo A23 for SRS?
I’m thinking of dipping my feet into the Parasound pool. Right now I’m considering buying a used 2250 or A23. They’re the same price.
I know the Halos are spec’d better, but the 2250 has twice the power. 400 wpc at 4 ohms vs 200 in the Halo. I like that the Halo has balanced inputs since I’m currently running a full balanced setup out of my Emotiva DC-1 preamp/DAC. Room is 11x22. I’m currently using SDA SRS 2 but I’m interested in finding some 3.1TL in the near future.
So I guess my question is: Will the A23 provide enough power to drive the SRS 2 or 3.1 TL comfortably? I don't want to lose any of the dynamics I'm currently getting with 525 wpc of class D power. Is there a noticeable difference in sound quality between the New Classics and Halo series?
Any other slightly used amps in the $600 range I should be considering?
  • Emlyn
    Emlyn Posts: 4,876
    I would go with the 2250 in that situation for the extra current capability, but would go for the A23 with any of the last recent generations of Polk speakers. You could also get a B&K 200.2 in that price range which I think would be a better choice. I doubt it will be as dynamic an amp as a Class D amp, but would be warmer and more musical sounding
    If you are buying either amp used you should be able to sell them on with no problem.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Agree with Skip... The A23 has plenty of power. don't get consumed with WPC. I have A23's and an A21 and you would not hear the difference unless you were driving inefficient speakers in a large room. The balanced connection to your pre will give you a lower noise floor with a good set of bal interconnects. I have used both amps with my SDS 2.3's and could be happy using an A23.
    Garage | Polk Monitor 5B's
  • Rex81
    Rex81 Posts: 193
    Thanks for the insights. We think of SDAs as being really power hungry, but they are fairly efficient after all. Seems like they more prefer the current. Certainly the A23 offers plenty of that. Glad to hear of some first hand experience.
    Now to seek one out...
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    Rex81 wrote: »
    Quite true. I'm running a 50 watt tube amp on my 1.2TL's, plenty of power and they sound great.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • [Deleted User]
    I use a Yamaha PC2002M with my SDA SRS 2s and it can work fairly hard with difficult passages. I say at least 150 a side.
  • michaeljhsda2
    Not trying to crap on anyone's amp choice but IMHO, watts don't mean squat. Well they do but it's all about the amps ability to deliver high current. If watts were all that mattered, then my Kenwood KR6030 (80 WPC) and KR9060 (160 WPC) should have sounded better than the 50 watt Yaqin tube amp. Both Kenwood's fell flat on their face.
    I also used a Crown XLS 402D (pro amp) rated at 380 WPC and the 50 watt tube amp sounded better in every way. Solid, tight bass, great midrange and highs with a nice full sound. The proamp was sterile, thin sounding and the midrange and highs were smeared.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    I would love to get my hands on a Parasound A23 or A21 and see how it fairs on the 1.2TL's but toobs sound so good.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Emlyn
    Emlyn Posts: 4,876
    The Parasound HCA-1500A would also be a good choice.
  • Rex81
    Rex81 Posts: 193
    Rex81 wrote: »
    Wow, I'm really surprised to hear that. Interesting. You don't notice any loss of dynamics, bass impact, etc? I never thought of looking into a tube amp, but those Yaqins are right in the same price range... Great, now my search just got broader. ;)
    Emlyn wrote: »
    Yeah, I was looking at the HCA series. Although I'd like to have a newer amp if possible. I don't want to have to service it any time soon.
  • motorhead43026
    motorhead43026 Posts: 4,051
    edited March 2016
    I own a less then year old A23 and it punches way above it's price point, and does it very well.
    Thank you for that fine description. It's exactly why most of us don't recommend pro amps for in home quality listening.
    ....and your right, watts don't mean as much as current delivery. If the OP is looking for a used amp in the 6 bones range, hard to top Parasound or B&k amps which gell well with SDA's. McCormack amps should also be on your radar, no loss of dynamics or bass response for that brand.
  • steveinaz
    steveinaz Posts: 19,546
    The HCA series use Jfet/mosfet setups just like halo, and the 1500 has 60amp capability.
  • Rex81
    Rex81 Posts: 193
    Ok, so lots of good things about the Parasounds, but now I'm seriously considering a Yaqin tube integrated. They're in the same price range, but brand new. I'll need to research this option more...
  • michaeljhsda2
    No loss of dynamics and room shaking bass. I've played bass heavy music including 20 Hz bass test tones to assess it's limits and the Yaqin/1.2 TL combo didn't flinch. More than enough power to pressurize a 13' x 18' room with an 8' ceiling.
    The MC-30L is an integrated amp and has a remote control (no phono preamp). Price to quality ratio is hard to beat. The amp has Shuguang EL34-B power tubes which IMO are an excellent tube. I've tried others but always go back to these. I seldom see a used Yaqin for sale so folks must really like them I reckon.
    Everyone that listens to the system can't believe it's "only 50 watts" and yet sounds that powerful...and great.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Rex81
    Rex81 Posts: 193
    Thanks for the info. I also see the MC-13S model. It's listed as an upgraded MC-10L. It also used EL34B tubes. Do you have any experience with this model? Looks like it uses 8 tubes instead of 12, 40 watts instead of 45, and doesn't have a remote.
    http://www.ebay.com/itm/Silk-Audio-MC-13S-Tube-Integrated-Amplifier-Factory-New-from-Yaqin-/322041457571
  • michaeljhsda2
    Rex81 wrote: »
    If you decide to buy one, get in touch with Ray, owner of Silk Audio, on Ebay. He's in the Chicagoland area. He sells the Silk Audio MS-38 which is a rebadged MC-30L. He services what he sells, great communication, fast shipping. Others on this forum have bought from him so hopefully they'll chime in.
    If you like the looks of the Yaqin MC-30L, get in touch with Tabnaac (Ebay ID). His name is Song interestingly enough and he ships out of Canada. Shipping to my home in the midwest was only 45 bucks and arrived in 3 days.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • boston1450
    boston1450 Posts: 7,758
    They are sexy too :)
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • michaeljhsda2
    Rex81 wrote: »
    I owned the MC-10L, it was my gateway drug into the world of tubes LOL. In fact, that was the amp I hooked up to the 1.2TL's and was blown away by how great it sounded. Rocked the house. I wanted the remote so I sold the 10L to my brother in law and got the MS-20L for the SDA 1C's and the 30L for the 1.2TL's.
    I would recommend either the 20L, 30L or the Silk Audio MS-38 (looks the best IMO).
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    boston1450 wrote: »
    Sure nuff! How do you like the CD player?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Rex81
    Rex81 Posts: 193
    I actually don't care for the look of the MS-38. I prefer the all-analog look of the MC-13S, but I think having the remote with the 30L would be nice.
  • michaeljhsda2
    Rex81 wrote: »
    For sure. Those days of getting up and down to adjust the volume are over. :smile:
    SDA SRS 2.3TL's
    SDA 2B TL's
  • boston1450
    edited March 2016
    Sure nuff! How do you like the CD player?[/quote]
    works great. Save your money. Ive A-B'd it against my Denon 2910 & didnt really hear that much gain. I actually got the cd player way before the amp. Im kinda backwards
    Randy-Maine
    by David WMG
  • michaeljhsda2
    Noted, thanks
    SDA SRS 2.3TL's
    SDA 2B TL's
    msg Posts: 10,552
    edited March 2016
    Wow! @boston1450 ! I had no idea those Yaquin pieces were so attractively built! - I really like those
  • Rex81
    Rex81 Posts: 193
    I did it. Pulled the trigger on a 30L from Silk Audio. Wow, that was a huge turn in direction from what I was planning, but I'm ok with it.
    Thanks michaeljhsda2 for your inspiration! I'll let you guys know what I think when it gets here!
  • Rex81
    Rex81 Posts: 193
    Oh, and thanks again for everyone's advice on the Parasounds. I'll continue to keep my eyes open for an opportunity to demo those.
  • michaeljhsda2
    edited March 2016
    Rex81 wrote: »
    Cool, congrats B) Do you have a voltage meter? Although Ray checks the bias before he ships it, double check to make sure it's reading 400 volts per tube. It's a cinch to do btw.
    I check mine every month or 3 and it's very stable.
    Although you have the 30L it's a good read...http://forum.polkaudio.com/discussion/165583/tubes-in-the-house/p1
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Rex81
    Rex81 Posts: 193
    Yes, I have a meter and know how to use it. I'll be sure to check.
    I'll check out the link. Thanks!
  • michaeljhsda2
    Are your SRS 2's stock?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,936
    Rex81 wrote: »
    Rex81, you have me looking at those on eBay too. You made a fast direction change.
    Harry / Marietta GA
