Remember to epoxy your woofer magnets!
  • lawdogg
    lawdogg Posts: 470
    Epoxying magnets is FUN!
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
    xschop Posts: 5,790
    xschop Posts: 5,790
    edited March 2016
    The 5.75" dimension needs to match the hand tool guide OD as a slip-fit tolerance. The extra length I put on the cylinder allows the guide tool to seat fully and center before magnet sets. The 1/2" diameter thru-hole needs to be there to relieve the internal pressure or the cone will blow-out.axoihmgc4okg.png
  • RandyCroissant
    I think you are on the right track with this, question what part will center the pole piece?
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • westmassguy
    westmassguy Posts: 6,850
    Be sure to observe proper magnet polarity when re-assembling, otherwise the woofer will be out of phase.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    xschop Posts: 5,790
    edited March 2016
    Randy, I believe the small hole in the back plate is the factory lathe turn center which would be concentric to the guidepost. It's 0.375 diameter on all ones I measured. It tapers at @ 0.200 depth so 0.175" length is the guide pin on above hand tool drawing. I would make the hand tool out of 4130 or 1018 steel so the magnet and back plate self stick to it after they are glued in first step.
  • RandyCroissant
    Ok I see what you mean, that should work.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
    xschop Posts: 5,790
    edited March 2016
    WMG, which way is N & S in relation to front and back plates?
    Is it not also imperative that the magnet ID be set 100% concentric to the guide post OD or the voice coil will have an off-axis pull when current is run?
  • westmassguy
    I doubt there are markings on the magnets, just hold one over an unmolested Polk woofer. If it attracts, its positioned right, if it repels, it's reversed.
  • RandyCroissant
    Dave is there anything you don't know!!
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • Nightfall
    Nightfall Posts: 10,083
    The meaning of life? :p
    afterburnt wrote: »
    Village Idiot of Club Polk
  • ken brydson
    ken brydson Posts: 9,098
    Women?
  • westmassguy
    Women?
    Once you fully understand them, you're on the wrong side of the lawn.
  • voltz
    voltz Posts: 5,384
    Nightfall wrote: »
    thats easy its 42.
  • boston1450
    boston1450 Posts: 7,758
    All that & it all leads up to
    42
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • Gunther16
    Gunther16 Posts: 243
    Dave is the speaker god, all seeing, all knowing. LOL
  • Sqeek
    Sqeek Posts: 2
    edited May 2021
    Thanks for having me my first post hear
    I had been putting this off for some time now but after reading about others nightmares i decided to take on the task B)
    I just got through with applying the power grab to my MW6502 buy the time i got good at spreading the power grab it was all over with lol
    I used this pushed inside to power grab tube to do the magnet base to the speaker basket it's simply one of the brushes you get with a re-foam kit with the bristles removed it worked perfect ! Ijust went ahead and used it for all the mating surfaces. b6083w2fd5wu.jpg
    she may not be the prettiest girl in the room but she will do lol ;)
    Next up is to buy the new tweeter upgrades
    audioluvr Posts: 6,065
    Nice work! Welcome to Club Polk.
  • Gardenstater
    Gardenstater Posts: 4,916
    Yes nice job and that will give you some peace of mind. For future reference, you don't need to glue between the basket and the pole piece plate nearest the cone. That must be spotwelded or swaged and not glued.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Sqeek
    Sqeek Posts: 2
    edited May 2021
    Thanks' Guys i appreciate your feedback and kind words
    Ok Thank you Gardenstater thats great information
    For future reference, you don't need to glue between the basket and the pole piece plate nearest the cone. That must be spot welded or swaged and not glued.
    Thought i would throw this little tib bit in for laughs the magnets didn't come lose but the speaker sticker that is usually on the back of the drivers was lying in the bottom of the Monitor 7 cabs i glued them back on also B):p
  • Gardenstater
    That's good. Just like the tags on pillows and so forth, you can go to prison for having one of those labels off.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • odcics2
    odcics2 Posts: 396
    I use a 30hz signal while re-foaming woofers to absolutely center the voice coil without removing the dust cap.
    Would that help in centering the magnet to prevent rub?
    If you were off a little, you'd hear it!
  • Schurkey
    Schurkey Posts: 2,125
    edited May 2021
    odcics2 wrote: »
    No, it does not help to actually center the magnet. It will let you know that things aren't right, though, so you can take action to correct what's wrong.
    Realistically, the MAGNET does not have to be perfectly centered, but the pole piece does.
    If you're applying epoxy on a speaker driver that hasn't already come apart, this isn't a concern. The factory alignment hasn't changed. If the pole piece or magnet has already shifted, though, you're going to have to "fix" the alignment and secure the pieces with some other adhesive BEFORE you apply the epoxy.
    When it was me, I cleaned the magnet and pole piece, secured the magnet to the basket with a generic equivalent to Loctite 271 high-strength anaerobic thread locker, then aligned the pole piece and secured it to the magnet with the same stuff. THEN the epoxy after the Loctite has cured. And yes, I was playing music through the speaker as I centered the pole piece as an indicator of alignment. There is not a lot of time to get the pole piece aligned before the anaerobic adhesive sets up. Work fast.
  • odcics2
    odcics2 Posts: 396
    edited May 2021
    I'd center the magnet and pole piece to the voice coil. No good reason to not do it...
    Playing music is the same as using a 30hz signal. So, you do agree with my method!
  • lawdogg
    lawdogg Posts: 470
    edited June 2021
    No. I would absolutely not play a test tone while re-centering the pole piece. Re-centering the pole piece is much different than re-foaming. While re-centering the pole piece, it will have a tendency to initially snap to one side and lock the voice coil in place as you get it started. I would NOT want the voice coil trying to move as I'm doing this.
    <3 my 3.1TLs
  • Schurkey
    lawdogg wrote: »
    That's why I used a fixture. Pole piece does not "snap" anywhere because it's stabilized by the fixture.
    mhardy6647 Posts: 35,550
  • lawdogg
    lawdogg Posts: 470
    Schurkey wrote: »
    That's great - how did you make it? How does it work?
    <3 my 3.1TLs
  • Schurkey
    edited June 2021
    lawdogg wrote: »
    Schurkey wrote: »
    I shamelessly stole the idea from Saftgeek.
    https://forum.polkaudio.com/discussion/135716/lets-try-to-fix-a-mw6511-damaged-in-shipping/p1
    I can't post photos. Here's links.
    http://hbassociates.us/Polk_Magnet_01.jpg
    http://hbassociates.us/Polk_Magnet_02.jpg
    http://hbassociates.us/Polk_Magnet_03.jpg
    http://hbassociates.us/Polk_Magnet_04.jpg
    pitdogg2 Posts: 27,869
    Schurkey wrote: »
    lawdogg wrote: »
    Schurkey wrote: »
    Gosh that was a good link !! Fun time we had back then. So many folks who no longer stop and say Hi.
