Garage Access Panel?
  • zingo
    zingo Posts: 11,258
    Good question. The inlet for the generator is already outside, but occasionally I want to run it in the garage with the door open to shield it. I could add a 240v outlet and air connector on the other side of the garage wall, but wouldn't it be easier to just add a pass-though since the "location" of the outlet wouldn't really change?
  • exalted512
    exalted512 Posts: 10,735
    So the outlet is already outside? What kind of exterior is your house?
  • zingo
    zingo Posts: 11,258
    The generator inlet is outside the garage wall and the 240v outlet is inside the garage. The house has vertical 1955 original wood siding over shiplap.
  • exalted512
    Sounds like it would be easier to just cut a hole for the cat door then. I just think (personally) that it would look nicer to have an outlet box and air connection than a cat door; but you're right, it would be a little more in-depth.
    -Cody
  • zingo
    zingo Posts: 11,258
    I don't disagree with you that it wouldn't look at good, but it would provide flexibility with many components.
    Maybe for a more professional look, a small locking access panel? Although it would need to be weather proof.
  • exalted512
    are the cat doors weatherproof?
    pitdogg2 Posts: 27,046
    edited March 2016
    exalted512 wrote: »
    some are somewhat. I've seen some with magnets on the sides to hold the door shut so not to be blown open by wind
