Garage Access Panel?
zingo
zingo Posts: 11,258
I keep my generator and air compressor in my garage, but want to run them outside to keep the noise down. Are there any products that allow a hatch/access panel for running the power cords and air lines through the exterior wall? I don't want to add hard airlines or outlet outside that wall, and it seems like a simple solution for occasional usage.
It would be great if a product existed for that, but I was also thinking a waterproof outlet box on both sides connected with 4" PVC pipe in the wall would provide a clean pass through?
  • Legender
    Legender Posts: 478
    It's probably over kill, but look at how your AC is powered up on the side of the house with an electrical box. If it's good enough for 220 AC power it should work for your compressor.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • lightman1
    lightman1 Posts: 10,796
    Legender wrote: »
    Mmmmm. Not recommended.
    In the summer months, you run the risk of overloading the circuit for the AC unit.
    An event of the air compressor and the AC compressor running at the same time will pop the breaker and/or overheat the wire. Bad ju-ju.
    Have a look-see at a small doggie door that you can shut/lock when not in use. That way you have room to run air lines or drop cords when needed and keep unwanted critters out.
    A dedicated circuit means just that. It serves a purpose for a particular piece of equipment.
    Safety tip for the day.
  • Legender
    Legender Posts: 478
    I wasn't recommending plugging into the AC box. That would be a no no. But look at the waterproofing of that set up. You could run power from the interior, terminate at a similar junction box and hook up power outside. Would never steal/borrow from a dedicated circuit.
    Only wanted to duplicate the connection method for your outdoor electricals on their own circuit, that's all.
  • lightman1
    edited March 2016
    ..double post
    Post edited by lightman1 on
  • lightman1
    edited March 2016
    @Legender ...got it. Misconstrued your statement. But being in the field for 30+ years, I have seen some crazy stuff people do to wire up equipment. One wrong move away from disaster.
    Plus I don't think his compressor is portable. Fixed unit ZingerDinger?
  • zingo
    zingo Posts: 11,258
    It's a wheeled air compressor, but 240v belt driven 2 cylinder, so I don't try to move it often. :)
    I like the idea of using a little cat door made for framed walls!
  • lightman1
    Have at it then. I gotta get back out to Seattle to see you folks again. Good times last trip. B)
    EndersShadow Posts: 17,688
    lightman1 wrote: »
    @zingo is still taking penicillin because of your last visit....
  • lightman1
    lightman1 wrote: »
    :o And about his missing garage.....it's mine now. ;)
  • zingo
    zingo Posts: 11,258
    Actually, after 2 years of penicillin, the free clinic switched me to something stronger as that growth still hasn't gone away...
  • lightman1
    Ask Brydson how he feels after that trip. ;)
    And Al (danger boy)??? Anybody heard from him?
  • lightman1
    No passport. I shall have to sneak across under cover of darkness. Or tip the guard. ;)
  • ken brydson
    ken brydson Posts: 8,988
    lightman1 wrote: »
    Still a little sore big man... Al is well, friends with him on FB.
    F1nut Posts: 51,700
    Ken, I don't do FB.....could you say hi to Al for me?
  • lightman1
    Same here Ken.
  • zingo
    zingo Posts: 11,258
    Al is a good guy.
    tonyb Posts: 33,068
    zingo wrote: »
    I like the doggy door idea, but keeping the units outside leaves them to the forces of nature. Condensation.....not good for air compressors I would think.
  • zingo
    zingo Posts: 11,258
    https://www.petdoors.com/cat-mate-234-235-and-wall-framing-kit.html
    This small cat door designed for wall installation would work great! I'll see what I can find locally; thanks ya'll!
  • zingo
    zingo Posts: 11,258
  • zingo
    zingo Posts: 11,258
    My air compressor and generator would be kept in that garage, but moved outside for use with the lines running through the wall. Thanks for all the suggestions and I'm going to look into getting a small cat door.
    FYI - I submitted the above post yesterday mid-day, and 18 hours later it shows up after "approval"; not sure why that was need and timely.
  • [Deleted User]
    [Deleted User] Posts: 7,658
    That is correct.
    tonyb Posts: 33,068
    edited March 2016
    So Zingo is of "suspicious" character ? I've had my doubts about him for a long time now. :):p
    " Why I bet he's even got a commie flag, tacked up on the wall, inside of his garage".
    You southern boys better know that tune.
  • lightman1
    Charlie Daniels. Uneasy Rider.
    What did I win, Tony? :p
    A bag of penne pasta?
  • zingo
    zingo Posts: 11,258
    No Commie flag on that garage wall, but I do have a Polk banner pinned up; does that get me off the hook? And a framed picture of my old dog.
    pitdogg2 Posts: 26,961
    tonyb wrote: »
    Hey I have one of those "commie hammer and sickle" flags hanging on my wall.....stole it fair and square.
  • ken brydson
    For @F1nut , @lightman1 and @zingo . Al says Hi back. Told him to pop in and he said he would....
  • zingo
    zingo Posts: 11,258
    I should work on hosting another CP Seattle Meet-up again; they are darn fun when we can make them happen.
  • lightman1
    Make it so #1....
  • exalted512
    exalted512 Posts: 10,735
    Just out of curiosity, why would you rather put a cat door in the wall as opposed to just putting a quick release air coupling and outlet on the outside wall?
