Does anyone run 3 subs?
I am thinking about it since I have a lot more space due to doors having to be left open to the rest of the house. Besides I found space for another lol.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I have 4 but only 1 of them is great...
    Garage | Polk Monitor 5B's
  • afterburnt
    afterburnt Posts: 7,892
    What others do you run besides the Ultra? I don't want to try and mix mine I dont have the brains or the patients to try to get them to play together.
  • Mikey081057
    edited March 2016
    mine are dispersed throughout the house... I have dual mp2ks with my Ushers... and some POS that came with my soundbar... just get a PB13 ultra and you won't look back...
  • afterburnt
    Mikey what is your room like with the solo PB13?
  • Bump up to one more and put one in each corner or wall midpoint and that's about as good as it gets.
  • mantis
    mantis Posts: 17,419
    I have ran 3 subs with no benefits. I tuned them all perfectly and where I sit I didn't get anything out of it.
    I have a badass M&K THX certified Sub actually I have 2 of them and I ran one of them with my ST's. I felt when I turned off the ST's and just ran them full range I had a tad better performance but when all 3 where on I felt that I wasn't gaining anything.
    More subs are for better coverage if you have coverage issues. In very large rooms 3 or 4 would work great but the room would have to be huge.
    I usually spec on my jobs 2 always no matter what as I feel 2 always work together better then just one. I can get one to work well but not cover the room with all the seating perfectly like 2 does.
    In some rare rooms I have used 4 and the room required it.
    Dan
  • mantis wrote: »
    Multiple subs are for fixing modal issues. Without them you have big nulls and peaks, especially when you change positions. Get four subs and put them in each corner or wall midpoint and seat to seat response is as good as it is going to get. Read up on some of Dr. Floyd E. Toole's writings and ramblings on this subject. Also play around with REW's room simulator and you can visually see how everything interacts.
