Ok. I admit. Im a mess
Ok i really am a mess. I have no idea what im doing here & really need help from folks who know better. I need a direction to be led.... My HT system vintage is this.
SDA1c fronts
Cs1000p center
yamaha rxv2600
Seems ok on power so far. Im gonna move gear around & add power amp to front speakers @ 220wpc to the SDA's
The cp1000p should i add a amplifier. I keep looking for a 3 channel or 5 channel amplifier & not sure what to do. Another concern i have is when i upgrade the SDA's the OHM's change & the Denon amp i like probably wont do 4ohm loads & if i recall the center is 8 ohm. Im a mess & not sure what to do
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Its time to look for a more serious amp if you have concerns. Peace of mind is sometimes only achieved when you spend a little more to get stability under load that the Denon may have issues with. Lots of choices, Rotel, Parasound, Acurus all carry multi channel amps that can do the job.
  • boston1450
    boston1450 Posts: 7,758
    would a 3 channel be ok & add it to my receiver-so i can use it on the tv for movies-video's & shows
    Randy-Maine
    by David WMG
  • westmassguy
    westmassguy Posts: 6,850
    Randy, once the 1Cs are off a separate amp, the Yamaha should have no problem powering the center (which has a 100 watt amp built in for sub-bass signals), and two or four additional surround/rear speakers.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • JPete
    JPete Posts: 295
    I was in your shoes for a while with my HT setup. Running a Pioneer VSX-1123 for all channels. Threw a 2 channel amp in for the fronts and it really opened up. Unfortunately that Pio only had preouts for the fronts... Now I've gone to a pre/pro with a 5 channel amp driving everything. There's no going back from that point, but I can say that getting the mains off the AVR amps really did help, in my case, for driving the center and surrounds.
    I think your results would be similar, and that's likely the least expensive way to proceed depending on the amp selection obviously.
    I wish I would have gone all in with the pre/pro and 5 channel amp to start with since it would have ultimately been less expensive, but the funds didn't allow this initially.
    What type of budget are you trying to keep here?
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
    Your not a mess, but you do need to feed those SDA's more power. Add a 2 channel amp, the center is self powered.
    Down the road though, I might look to swap out that Yammie receiver, not doing you any favors SQ wise imho.
  • rooftop59
    rooftop59 Posts: 8,120
    tonyb wrote: »
    That yammie is a pretty stout receiver, and sounds pretty darn good in "pure direct" mode for two channel. Pretty stout as well: http://www.audioholics.com/av-receiver-reviews/yamaha-rx-v2600/yamaha-rx-v2600-benchmark-performance-tests
    Now of course, nice separates would be an improvement, but that yammie waslks oer anything you can get currently at best buy...
    I would leave the center alone for now and power the mains separately. But I will say that I have powered the non-powered part of the cs1000 (the sc400i) with a little audiosource amp200 (80 wpc) and it was a BIG improvement...
    Game Room 5.1.4:
    Bedroom 2.1
  • boston1450
    I will try the amplifier on the SDA's. I will try the Denon poa2200 for HT. I didnt want to use the Adcom on the 1c's. CRS's will eventually be on that. Im stockpiling money & gear sales for a amplifier that might do everything. (I hate selling my old gear i like-but dont need). Budget under 2 grand in due time. If i got to change everything out. I will. Thanks for feedback & i will report back on how the Denon does with the receiver hooked to it
    Randy-Maine
    by David WMG
  • boston1450
    Im fixing things up :)
    Randy-Maine
    by David WMG
  • Easy Runnin
    Easy Runnin Posts: 501
    Are 1Cs a good choice for HT? How well will YPAO work with dimensional drivers? Wouldn't it be a better idea to offload the low end to a good sub and find some fronts that are easier to drive without dimensional drivers?
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • boston1450
    edited March 2016
    I have used 2b & 1c's for HT in RXV1 w/200+wpc-2chAmp with a cs400i w/Moniitor 4's for rears & it sounded pretty good. Im just not good with 3 4 5 channel amplifiers
    Randy-Maine
    by David WMG
    boston1450 wrote: »
    Same process as the 2 channel amp, whats not to get ? Besides, if it sounds good now, why mess with it ? Know the old saying... if it ain't broke don't fix it ?
  • boston1450
    ? Would be when using a 3 channel amplifier & 2 of the speakers are 6 or 4 ohm & 1 is 8 ohm
    Randy-Maine
    by David WMG
  • Schurkey
    Schurkey Posts: 2,122
    edited March 2016
    boston1450 wrote: »
    Makes not the faintest difference IF (big IF) the amplifier is rated for the 6- or 4-ohm nominal load.
    Speaker impedance varies with frequency. Two stereo channels aren't producing the same frequencies most of the time. Your speakers are already producing a different load to the amplifier based on the signal volume and signal frequency.
    Adding a third, un-matched speaker won't do anything except make for a bit more load on the single power supply in most amps, and other amps would have a separate power supply for each channel.
    Getting the appropriate volume level with the mis-matched speakers is a job for your preamp/processor. About all that leaves you with is the voicing difference between the two similar speakers, and the one different one.
  • boston1450
    Thank you for feedback. That helps when making choices on different amplifiers to look for
    Randy-Maine
    by David WMG
  • TennMan
    TennMan Posts: 1,266
    Should the interconnect cable be unplugged when setting up SDAs with YPAO?
  • boston1450
    Whats a YPAO ? Is that the mic you plug in ? If so i have one but do it by ear
    Randy-Maine
    by David WMG
  • TennMan
    YPAO is Yamaha's automatic speaker calibration system that is included with some of it's AVRs. It does use a microphone. Seems to me like YPAO and similar calibration systems would really be confused by the dimensional driver in one speaker playing at low volume while it is testing the other speaker. I was just wondering if it would be better to unplug the interconnect cable to avoid any problems when using automatic calibration. Maybe a manual setup would be better with SDAs.
  • boston1450
    I just switched out the rxv1500 & put the rxv2600 in its spot. So far,so good. I didnt really adjust much on it & probably wont till i get the new to me amplifier in. I will report back. Thanks guys
    Randy-Maine
    by David WMG
  • ken brydson
    ken brydson Posts: 9,010
    boston1450 wrote: »
    YPAO = Yamaha Parametric Acoustic Optimiser...
    https://www.youtube.com/watch?v=guw5g2aSdgs
  • boston1450
    Got one of those with a tripod. Work pretty good & hear noises i never heard before when i did finally use it :)
    Randy-Maine
    by David WMG
    edited March 2016
    Looks like you've gotten excellent feedback. Two channel power amp is what I would use first. I've done that even on my non-SDA HT. It makes a "HUGE" difference he said, gesticulating like a billionaire! lol
    The Yammie should be able to handle everything else. Ohms will be irrelevant once the power amp is in place!
  • boston1450
    That wasnt my issue. It was using a 3 channel amplifier for the fronts & center at the same time-with the 3 channel amplifier that had me confused. Ive used 2 channel amp on HT with great results..... I had to ditch my Paradigms because i have too much stuff & i didnt want to rid of SDA's or Monitors ive had & enjoy. Down the road i can do new HT once i have room for more & real mancave back
    Randy-Maine
    by David WMG
