Polk Monitor 7 - crossovers going south?
DozerCSX
Greetings - I am the original owner of a pair of Polk Monitor 7s from 1986, and I had them in storage for 10 years; now that they're back in action, they seem as accurate as ever, but I sense the bass has been reduced somewhat from what I recall. Can anyone tell me whether this might be a result of the crossovers weakening, or going bad? Would inactivity affect the crossovers? Is there a way to check their health?
HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
Sides: Polk VX300i surround speakers
Subwoofer: Pioneer PSW-8mk2
Receiver: Denon AVR-S750H
Office: Panasonic SB-PM27 speakers (bi-amp mode)
Receiver: Panasonic SA-XR57 (bi-amp mode)
The Crossovers have Mylar and NP Electrolytics. Mylars don't age, but Electrolytics do.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Check for air leaks? I'd start there for missing bass.
Torn rubber surrounds on any of the drivers or passive radiators?
Are you playing them in the same room you played them 10 years ago? Is the equipment the same? Cables the same? Lots of variables.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Welcome. Yes, it's probably time to refresh the crossovers, always a good idea on 30 yr speakers. I would also check the Dacron insulation in the cabinets. Take the passive woofer out & push the Dacron back up towards the tweeters. It should not be below the passive. This will give you a better bass and will tighten them up a bit.- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, BH5, JB Welded, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- Pioneer SC-1222K AVR
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 AVR
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG -
Thanks guys - great ideas to work on - I just did a quick inspection for leaks - they are in almost perfect condition, nothing obvious; I did notice that the left speaker is sitting on a thin, flexy half inch plywood, which is clearly sucking up at least some of the sound energy - I'm putting them on polymer feet over solid wood bases tonight to see if that helps; pending on that outcome, I'll see about "opening the patient... BTW here are some pictures - they are 7Cs, with a story - in the 1989 SF earthquake, the right speaker fell on its face and damaged the tweeter, so I replaced it with a Peerless - the original SL2000 is still on the left speaker...
Receiver: Panasonic SA-XR57 (bi-amp mode) -
That tweeter looks like the Rdo 194 that is a replacement for the sl2000 and is a lot smoother sounding tweeter.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
That's not a Peerless, looks like a SL2500. Replace both with RDO-194's, they can be bought directly from Polk.
They look like they're in pretty good shape, nice speakers.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Turns out the right side replacement tweeter is an RDO 194, not a Peerless - I purchased it directly from Polk at the time - and it is a bit smoother sound than the original... yeah, probably time to pick up another and "make 'em match."HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
I thought you replaced the tweeter in 1989?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I damaged it in 1989, I didn't fix it for several years afterwards (I stored them for a while then, as well) - probably like you, I've gone through many, many speakers over the last 30 years... ;-) But I've kept these as my personal favorites, kind of like my 1989 pickup truck.HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
So, I've done a couple of sound checks and inspections last night - the environment I'm using now (a garage) is much bigger than where I've previously used these - but the cables and gear are actually higher quality than before; the room definitely swallows a lot more of the sound, the speakers are further from the wall, and even raised with pads off the pressboard; still, I think they are down on bass. Any recommendations on crossovers or kits? I've never attempted anything like a crossover upgrade before, insights appreciated!HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
How big is the garage? I suspect much bigger than the Monitor 7's are capable of pressurizing properly. You might need a sub.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
You may be right - it's a detached two car garage, 19'lx17'wx10'h - interestingly my RT800i's could do the job out there, but they had two 6" woofers, plus a large ported tower enclosure; when I put my ear next to the M7 woofer and PBR I can hear the lower octaves, but it does seem to get swallowed up in the room moving just a short distance away. I may try my sub out there and see what happens this weekend...HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
Gents - so, I think I got it sorted out - turns out there was a bit of pilot error - I use a Parasound AVR-1805, and I had the L/R speaker toggle set to "small", not "full range" - I did get back some low bite in correcting the setting, but the whole exercise allowed me to convince my wife to let me pick up a Polk PSW10 - now with the combination of Monitor 7c's running full range plus the PSW10 all set up and driven properly, I can now overwhelm my garage insulation with full range sound... thanks! (Based on your inputs I'll still be picking up a matching tweeter, and look in to new crossovers, but for now things appear to be working well)HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
Glad you got it figured out. Enjoy your Monitor 7's once again, they're great speakers.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Gents - so, I think I got it sorted out...the whole exercise allowed me to convince my wife to let me pick up a Polk PSW10
Monitor 7s. (Sweet!) Check.
New tweeter. Check.
PSW10. Noooooooooooooooooo!
A new/used sub will fill out your sound nicely, but the one you're looking at is the first one I'd tell you to move on from.
At a minimum, if you are sticking with Polk, I'd go psw110 or 505. However, the PSWPRO440wi or 550wi, or even the psw111, would serve you SO much better.
Others here will certainly chime in with some non-Polk suggestions too.
Chuff chuff chuffafterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Re: PSW10 - found an online fix which takes 10 minutes and completely removes the "chuff" - massive sonic improvement, check it out:
https://www.youtube.com/watch?v=gKsMdcjh8KM HT1: Polk Monitor 5jrS2 L/R, Polk CS400i center (bi-wire)
Sl2500 and Sl3000 have a foam ring around the dome (between the bezel). For future info.
And sometimes they turn a goldish color, this is an SL3000, but the foam ring looks the same on a SL2500
A RD0 replacement for reference
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
The RD0 replacements have been around for a long time, not as far back as 1989 though.....sometime in 2001,2002, IIRC. They were referred to as the SL2000T at that time.
Someone will correct me if I'm wrong"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Here is a post from 2003, but I know the SL2000T was available prior to this post.
http://forum.polkaudio.com/discussion/comment/113462#Comment_113462"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I currently have a 404 mated with my 7Cs and it sounds pretty good. I keep the volume down and let the 7s do most of the work. Just a little bottom end fill is what I was looking for.2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
2cents post from what I have been reading on the forums about tweeters and crossovers and such, mostly from westmassguy. If you are planning on rebuilding the crossovers, you might consider upgrading both tweeters to the RDO-198's vs the RDO-194's. I think the only change to use the RDO-198's is a different capacitor value on the crossovers (TL upgrade), but are a physical drop in replacement and according to most people here sound a little better than the RDO-194.
The wiring schematics have disappeared for the moment, so double check on the changes to the crossover if you go with the RDO-198.
