If it was'nt for bad luck..........
Gunther16
Got my Crossovers back from Westmassguy, who did an awesome job. Got everything back together and was ready for some break in time. That's when Murphy struck and decided to throw me a curve ball. Decided to put the voodoo on my Krell Amp. Thank the heavens my old trusty Adcom 555II, previously in storage, is still up to the task and out of storage. Still holding judgement on the upgrades for now.
Sad....Was it Snap, Crackle, or Pop that did them in?
I'm burning in another set of Xovers and this time I put them on a crappy shop amp. The exact same first 15min or so on the Caps and resistors make some of the strangest iterations as the last set.Don't take experimental gene therapies from known eugenicists. -
What is your preliminary observations and which caps did you choose? Did you do the inductors?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I've been down since I began to crawl...- SDA 2B (1989, Oak Tops, 194s, Spikes)
- Monitor 7B (1982 Peerless, Sonicaps, Mills, BH5, JB Welded, Binding Posts)
- (2) SVS SB12-NSD (Flat Black)
- SVS SB 3000 (Gloss Black)
- Pioneer SC-1222K AVR
- Marantz MM 7055 (5 Ch Amp)
- Pioneer PD-D6 SACD Player
- Marantz NR1403 AVR
- Sony UBP-X800M2 (4k Blu-ray)
- Sony UBP-X1100ES (4K Blu-ray)
- Adcom GFA 555 Amp
- Monitor 5 (194s, Side Surrounds)
- Monitor 5Jr+ (194s) {Storage}
- LG OLED65CXPUA (4K OLED TV)
- LG 55UN7300PUF (4K HD TV)
- RT35i (Cherry)
- (2 Pair) RT25i (Cherry)
- CS400 (Center)
- CS350 (Center)
- F/Xi A4 (Rear Surrounds)
- RT25 (Rear Surrounds) {Storage}
- Audioquest Interconnects
- Blu-Jean Speaker Cables & Interconnects
" But boy do I remember the strain of her refrain " LG -
No, no snap, crackle pop just an constant buzz from one channel, crap! Its off to Krell for an overhaul. Still breaking in the Crossovers using the Adcom, I got the Sonicaps, Gimpods Boards, Mills Resistors but on advise left the coil inductors alone. Twas quite a change and they are sounding better every hour that passes. It takes time. So far I'm noticing subtle differences.
The 3.1s only have one Dimensional woofer. Changing the Sub-Bass Drive Inductor would not have made any appreciable difference in the deep bass response of the speaker. The board lever inductors were hand tuned to < 1% tolerance between the two crossovers.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Sorry to hear about the Krell Gunther. Plan on at least 200-300 hours burn-in before everything settles in.Home Theater/2 Channel:
westmassguy wrote: »The 3.1s only have one Dimensional woofer. Changing the Sub-Bass Drive Inductor would not have made any appreciable difference in the deep bass response of the speaker. The board lever inductors were hand tuned to < 1% tolerance between the two crossovers.
Does this apply to 2A's and 2B's as well?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
No. With the 2A/Bs, 50% of the deep base comes from the Dimensional woofer.westmassguy wrote: »The 3.1s only have one Dimensional woofer. Changing the Sub-Bass Drive Inductor would not have made any appreciable difference in the deep bass response of the speaker. The board lever inductors were hand tuned to < 1% tolerance between the two crossovers.
The increased bass response is quite noticeable. Same applies to the CRS+s.
Thanks David, op to about 50 hrs burn in time now. Sounding smoother and cleaner as time passes. Happy camper so far. Thanks for all the advice!
Tough little suckers, those Adcoms.Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends -
Yes that they are and not bad for the $$$$$ either!
https://youtu.be/ZAAKPJEq1Ew
