Tube Question
boston1450
in Electronics
Are EL34'B' tubes pretty much the same as EL34 tubes ?
If so-just curious why the B ? Thanks in advance
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
by David WMG
Good question..maybe Marvin can answer this?
here a question ask by him.. opps back in 2012
http://www.audioasylum.com/cgi/vt.mpl?f=tubes&m=245852
Interesting read ^^^^ thanks. Being fairly new to tubes im just trying to see what different ones i can use where my amplifier has EL34b's. Id like to roll some different typesRandy-Maine
by David WMG
Yes, they should be the same. I don't believe they are any different other than from a different manufacturer so they may or may not sound different.
Give the JJ E34L tube a try. The Russian SED =C= (winged C) EL34 tubes are excellent, one of the best.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
try the eh 6ca7.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Thank you. Gives me some other options to trying different onesRandy-Maine
by David WMG
EL34B was assigned to the "New Sensor" mana tired Tung Sol labeled EL34. Funny thing is there was never even an original Tung Sol EL34 back in the 50s or 60s. Totally interchangeable with EL34s or 6CA7s. Another option is the KT77.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Ive read the KT77's are good. Those will fit too ? Being newbee to tubes i havent yet learned what will fit - where these are el34b's. Thanks for feedbackRandy-Maine
by David WMG
what amp/amps will you be using the tubes in?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
KT 77's are not compatible with Yaqin and Silk EL34 based integrated amplifiers.SDA SRS 2.3TL's
SDA 2B TL's -
Got ya Yaqin ms30L.... Sorry guys i shoulda mentioned integrated amp & brandRandy-Maine
by David WMG
