Tube Question
Are EL34'B' tubes pretty much the same as EL34 tubes ?
If so-just curious why the B ? Thanks in advance
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
MIT BJC Cs1000p Polk Rotation
  • voltz
    voltz Posts: 5,384
    edited February 2016
    Good question..maybe Marvin can answer this?
    here a question ask by him.. opps back in 2012
    http://www.audioasylum.com/cgi/vt.mpl?f=tubes&m=245852
  • boston1450
    boston1450 Posts: 7,758
    Interesting read ^^^^ thanks. Being fairly new to tubes im just trying to see what different ones i can use where my amplifier has EL34b's. Id like to roll some different types
    Randy-Maine
    by David WMG
    heiney9 Posts: 25,552
    Yes, they should be the same. I don't believe they are any different other than from a different manufacturer so they may or may not sound different.
    Give the JJ E34L tube a try. The Russian SED =C= (winged C) EL34 tubes are excellent, one of the best.
  • marvda1
    marvda1 Posts: 4,964
    try the eh 6ca7.
    Puritan PSM156
  • boston1450
    Thank you. Gives me some other options to trying different ones
    Randy-Maine
    by David WMG
  • doctor r
    doctor r Posts: 837
    EL34B was assigned to the "New Sensor" mana tired Tung Sol labeled EL34. Funny thing is there was never even an original Tung Sol EL34 back in the 50s or 60s. Totally interchangeable with EL34s or 6CA7s. Another option is the KT77.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • boston1450
    Ive read the KT77's are good. Those will fit too ? Being newbee to tubes i havent yet learned what will fit - where these are el34b's. Thanks for feedback
    Randy-Maine
    by David WMG
  • marvda1
    what amp/amps will you be using the tubes in?
    Puritan PSM156
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    KT 77's are not compatible with Yaqin and Silk EL34 based integrated amplifiers.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • boston1450
    Got ya Yaqin ms30L.... Sorry guys i shoulda mentioned integrated amp & brand
    Randy-Maine
    by David WMG
