Vincent preamp in the cart ready to purchase any feedback would be great!
http://www.audioadvisor.com/prodinfo.asp?number=VISA31
So I have exhausted myself looking for a tube preamp and think I found a winner, can somebody anybody put in their 2 cents plus recommend me a tube phono preamp to go along with it input on both Please :#
  • Nightfall
    Nightfall Posts: 10,083
    Decaware!
    afterburnt wrote: »
    Village Idiot of Club Polk
    gudnoyez Posts: 8,183
    http://www.needledoctor.com/Vincent-Audio-PHO-8-Phono-Preamp?sc=2&category=36638
    Perhaps a matching Vincent Phono Pre will do the trick, that Decaware is to rich for my blood. My decision is keeping me up at night, got to come to a decision right fast.
  • Nightfall
    Who is it that just got that, @voltz was it?
    afterburnt wrote: »
    Yeah I think Daryl got one but the next model up, perhaps he will chime in. Daryl where you at?
  • That Vincent looks like a nice piece. What's not to like? Good price, MM or MC, external PS. Pull the trigger. :)
    heiney9 Posts: 25,583
    Kind of an odd tube 6n16, not sure what you could actually use when rolling tubes. I am always a little suspect of odd tube designations. Haven't done a lot of research on that tube. But my guess is you will be limited to any other choices w/o modification.
    Just an FYI
  • megasat16
    megasat16 Posts: 3,521
    Hybrid, it says? I would presume it's a tube buffer with the Solid State Output stage.
    Neither a true Tube Pre Nor a good pure SS Pre. Probably the best of both world. But probably a bust as well. But but there is 7 glowing review on this atrocity.
    Roll the dice and tell me if you like it. I heard Vincent can sound good but used to be rigged with reliability problems.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited February 2016
    I would get the next model up.
    This one sounds fine but the noise floor was too high for me.
    I went SS pre and I'm holding myself back from getting
    a really good tube phono pre.
    Oh, and no tube rolling for you if you buy it.
  • voltz
    voltz Posts: 5,384
    Hey Steve, Sorry I been working a lot of OT, just got home from working 8 more :(
    I had that preamp and sold it to RED only because I upgrade to the SA-31 MKII, it is a hybrid and the tube cant be change out instantly as It is soldier in, I have not open my MKII to see if its the same way or not.
    But you can change the tubes on most of the other Vincent gear! I really like the Vincent stuff and have the maytching Amplifier and phono amp the PHO-8
    The SA-31 Preamp was my first 2 channel preamp and I bought it because the price was right...just no remote :(
  • Hasn't Musical Fidelity used a similar, soldered versus socketed, small signal tube successfully in their integrated gear for years?
  • voltz
    voltz Posts: 5,384
    I hear that is why they choose the 6N16, so it would last for long time.
    the regular SA-31 has a set of tubes in the output stage..the MKII version has 2 sets of tubes with 1 set in the input stage and 1 in the output stage and a remote.
    msg Posts: 10,534
    +1 on the PHO-8 phono pre.
    D turned me on to that little 2-piece unit when I was first looking for a phono pre, and I've not been disappointed. I'm using MM, so not sure how it works with MC. I find it to be a pretty clean, sweet and smooth little no-frills phono pre. Very nice build quality, imho, esp. for the cost; weighty, and looks nice in a phono rig. No regrets on that acquisition.
  • MrBuhl
    MrBuhl Posts: 2,419
    +2 on the Pho-8, and for that matter, the tube Pho-700. Have 'em both and enjoy them both!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    http://www.audioadvisor.com/mobile/prodinfo.asp?number=VISV237
    Thanks for the advice everyone, I will probably end up getting this integrated instead going to look around a bit more but find myself wanting this now along with the Vincent Pho-8. I could also see myself with the SA-31MK with Vincents tube phono stage the Pho-700
  • voltz
    voltz Posts: 5,384
    I think your going to love that Integrated amplifier if you do buy it as @Wardsweb has the SV237 and said he really likes it. I know Skip on some of the others was at a get together at his house and have heard that Amp! plus it is pure class A for the 1st 10 watts :) plus a nice heavy metal remote. (not plastic)
    I have the SA-31MK preamp + SP-331 Amplifier which would cost $3000 so its a pretty sweet deal!
