CRS+ Blade Blade HELP
Toolfan66
Okay I was wrong on the 2.3's being able to use the Dreadnought, what about the CRS+ Blade Blade, can the Dreadnought be used??
Larry I do not think any true Blade/Blade can be used with Dreadnought. Now if they used a B/B socket on a P/B you may be ok.
At least that is my take on what I've read here......I could be way wrong... -
If both serial numbers are 9371 or greater, yes.Political Correctness'.........defined
President of Club Polk -
Thanks Jesse, I will see what he has, I just didn't want to give out any false info..
Might want to pull one of the woofers and have look inside just to be sure. I've been seeing some weird stuff lately, and it's not the mushrooms.Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »Might want to pull one of the woofers and have look inside just to be sure. I've been seeing some weird stuff lately, and it's not the mushrooms.
And what would I look for? I have seen the innards, I just don't know what the serial #'s are at the moment because I am at work.. -
https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26707.pdf
I do know this is the speakers... -
Larry, that's 3rd generation, expensive to upgrade, and cannot use the Dreadnaught.Home Theater/2 Channel:
I love mushrooms.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
If it's a split crossover, it's 3rd generationHome Theater/2 Channel:
So would this be a B/B socket used like a P/B socket? -
All I can tell you is what I wrote previously.
Definitely can't use the Dreadnought, I was pretty sure that was the case anyways..
Thanks guys...
