Speaker Cable Hook up on vintage SRS-SDA's
As we all know there are 4 binding posts per speaker on the SDA lineup. In a conventional hookup (non bi-amped) I've been using the upper posts for hookup with jumper of course. As I'm in an upgrade right now I was wondering if it mattered whether one used the upper or lower binding post and why. With all you Polk Gurus out there can someone provide a real and logical answer to why one would choose one over the other?
Best Answer
Answers
  • YOU HAVE A KRELL?!?!
    HATRED
    JEALOUSY!!!
    (*snicker*)
    Anyhoo I also own a pair of 3.1TL's and have never been able to detect a difference between using the upper or lower binding posts when single wiring with the jumpers.
    I would LOVE to hear what these things sound like with some Krell bass!
  • Btw in the SDA lineup ONLY the Signature series SDA-SRS loudspeakers had dual binding posts.
  • Yo Honestaquarian, they did sound sweet with the Krell, in upgrade mode right now, we'll hear after upgrade and I'll provide an opinion then.
  • honestaquarian
    honestaquarian Posts: 3,260
    Hey man
    I was wondering what your opinion of them with the Krell now that you have done the upgrades?
  • motorhead43026
    motorhead43026 Posts: 3,997
    ^^I think the Krell went up in smoke^^
    – Kevin Alfred Strom
  • Gunther16
    Gunther16 Posts: 243
    Krell back and connected. All I can say is that all the mods made to the Polk was worth the effort and expense. They have never sounded sweeter. And yes the amp definitely contributes to sound quality. While the Krell was out I used an Adcom 555II which was ok but really not to up to par with the Krell.
