TriangleArt Reference SE prototype in the house!
You are putting together a serious analog source. Can't wait to hear your impressions of the completed project and see some pictures.
P.S. Don't forget to wear a back brace!
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Wow, that will be an awesome setupPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The arm will be here by end of the week. I am torn on whether I want to get the cosmetics done first or if I want to hear it first....
...HEAR IT...may bring inspiration2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
the chrome is going to cost 1600.00, so yeah, I will be listening to it for a while.
lol
Set up in my rig, waiting for the Tonearm to give it a voice
It's movement is dead silent, and zero vibration is being transmitted to the cabinet.
BOIINNGGG2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Seeing it where it belongs makes me question doing anything more than polishing it. It really jumps out at you. The table itself took all of ten minutes to set up and level. Very easy to work with, and also very easy to pinch fingers with.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Honestly John you're into the unit at a awesome price. It already looks beautiful as-is, i would enjoy it for now. If later you get a wild hair and want a change the so be it. Just get her singing and enjoy
Congrats man
So what's the scoop with installing the tonearm, any serious mods for arm boards etc needed????2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
It should just bolt right up, and it will be here wednesday. Trying to figure out what the first lp should bePost edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I think you need to get rid of your center.. it takes away from it lol....
Mount it above the TV, or just go Phantom center... Lord knows the SDA's should be able to handle that"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I am looking into an in-wall center now...EndersShadow wrote: »I think you need to get rid of your center.. it takes away from it lol....
man that platter make those tube amps look small.....you need bigger tubes....
that is a sweet set up I hope that table is up to the task. -
I don't know how the heck I missed this thread until now, but WOW...that is a beauty. Hope the arm is easy to get running because I can't imagine how badly you want to get spinning!2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
If you mean the cabinet the table is on, it is built into the wall and framed out inside with 2x4's. Should be just fine.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
+2 - that is an amazing TT John - don't know how I missed this - absolute beauty - though I have to say... I still get the wood for those Carver amps. Badass setup all the way around!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Outstanding choice. I have used an Origin Live Encounter mk3c for the past 4 years and love it. (I actually looked at that AudioGon listing, but .......). I would be happy to share my insights. Presently have a Ortofon Cadenza Bronze mounted with smile inducing results.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
That drone will never get off the ground...
That is absolutely spectacular!!!!!! Can't wait for you to get the tonearm mounted and hear your impressions. Congrats!
Since I was robbed of the Oppo karma...I cast a pox on your TT......
That's just dead sexy! -
The worst part of shooting that high on the analogue target usually results in most of your vinyl collection being shelved for better copies since anything that has more than 2 pops and a click will be considered unlistenable........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
If that happens Dennis, I will admit defeat and tell jesse he's right. Then I will just listen to music on my Bose I-dock and be done with all of it.
What do you do for record cleaning, John?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I need some help in that department. The current method is a very soft terry cloth towel and a soft microfiber brush, warm water with a couple drops of dawn.What do you do for record cleaning, John?
Dionized water rinse and microfiber dryThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
When you get into this realm of vinyl, cleaning isn't an option.
You're supposed to listen once, throw away, buy new record....in that order.
Looks like there is a RCM in your near future. Life just got more expensive!
I didn't notice, do you have a cart in mind already?Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
I think it's time for an ultrasonic cleaner. Plus it will go nicely with the Triangle.
http://hifiheaven.net/shop/Clearaudio-Double-Matrix-Professional-Sonic-Record-Cleaning-Machine?language=en¤cy=USD&gclid=Cj0KEQiArou2BRDcoN_c6NDI3oMBEiQANeix5vMTEln_kgQH0YSjhPzA6z0XALD4c4mTYD35f5TOipcaAha-8P8HAQ
Not to mention, it's silver, not black!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
John, that is a beautiful piece of gear! I agree with others that it looks great in its current finish. can't imagine needing to change that. Put your coin into things that will make it sound its best. Also agree you need to ditch the center and get an in-wall. I tried phantom center with the 2.3TL's and it just isn't the same.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
The tonearm is out for delivery today...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
John, your new table is surely a piece of Art. I'd say shine that bad boy with some Mothers Billet Polish.
http://www.amazon.com/Mothers-05106-Billet-Metal-Polish/dp/B000COU7LG/ref=sr_1_1?ie=UTF8&qid=1453924431&sr=8-1&keywords=mothers+billet+polish
This stuff is easy to apply and buff by hand, and leaves a beautiful finish.
is mothers better than Fitz? I seen some amazing finishes with Fitz.
