TriangleArt Reference SE prototype in the house!
245
  • Nightfall
    Nightfall Posts: 10,083
    You are putting together a serious analog source. Can't wait to hear your impressions of the completed project and see some pictures.
    P.S. Don't forget to wear a back brace! ;)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • vmaxer
    vmaxer Posts: 5,121
    Wow, that will be an awesome setup
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    nooshinjohn Posts: 26,002
    The arm will be here by end of the week. I am torn on whether I want to get the cosmetics done first or if I want to hear it first....
    txcoastal1 Posts: 13,519
    ...HEAR IT...may bring inspiration
    the chrome is going to cost 1600.00, so yeah, I will be listening to it for a while.
    lol :D
    edited February 2016
    Set up in my rig, waiting for the Tonearm to give it a voice05yb7smtkehj.jpg
    8lyw6ybqfojk.jpg It's movement is dead silent, and zero vibration is being transmitted to the cabinet. B)
    BOIINNGGG
    Seeing it where it belongs makes me question doing anything more than polishing it. It really jumps out at you. The table itself took all of ten minutes to set up and level. Very easy to work with, and also very easy to pinch fingers with.
    Honestly John you're into the unit at a awesome price. It already looks beautiful as-is, i would enjoy it for now. If later you get a wild hair and want a change the so be it. Just get her singing and enjoy
    Congrats man
    So what's the scoop with installing the tonearm, any serious mods for arm boards etc needed????
    It should just bolt right up, and it will be here wednesday. Trying to figure out what the first lp should be
    Post edited by nooshinjohn on
    EndersShadow Posts: 17,723
    I think you need to get rid of your center.. it takes away from it lol....
    Mount it above the TV, or just go Phantom center... Lord knows the SDA's should be able to handle that
    I am looking into an in-wall center now...
    pitdogg2 Posts: 27,343
    man that platter make those tube amps look small.....you need bigger tubes....
    that is a sweet set up I hope that table is up to the task.
  • hochpt21
    hochpt21 Posts: 5,423
    I don't know how the heck I missed this thread until now, but WOW...that is a beauty. Hope the arm is easy to get running because I can't imagine how badly you want to get spinning!
    If you mean the cabinet the table is on, it is built into the wall and framed out inside with 2x4's. Should be just fine.
  • MrBuhl
    MrBuhl Posts: 2,419
    hochpt21 wrote: »
    +2 - that is an amazing TT John - don't know how I missed this - absolute beauty - though I have to say... I still get the wood for those Carver amps. Badass setup all the way around!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • doctor r
    doctor r Posts: 837
    Outstanding choice. I have used an Origin Live Encounter mk3c for the past 4 years and love it. (I actually looked at that AudioGon listing, but .......). I would be happy to share my insights. Presently have a Ortofon Cadenza Bronze mounted with smile inducing results.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • ken brydson
    ken brydson Posts: 9,025
    That drone will never get off the ground...
  • Dawgfish
    Dawgfish Posts: 2,554
    That is absolutely spectacular!!!!!! Can't wait for you to get the tonearm mounted and hear your impressions. Congrats!
  • lightman1
    lightman1 Posts: 10,797
    Since I was robbed of the Oppo karma...I cast a pox on your TT...... :#
    That's just dead sexy!
  • The worst part of shooting that high on the analogue target usually results in most of your vinyl collection being shelved for better copies since anything that has more than 2 pops and a click will be considered unlistenable........
    If that happens Dennis, I will admit defeat and tell jesse he's right. Then I will just listen to music on my Bose I-dock and be done with all of it. :D;)
  • Nightfall
    What do you do for record cleaning, John?
    afterburnt wrote: »
    Nightfall wrote: »
    I need some help in that department. The current method is a very soft terry cloth towel and a soft microfiber brush, warm water with a couple drops of dawn.
    Dionized water rinse and microfiber dry
  • mrbiron
    mrbiron Posts: 5,721
    When you get into this realm of vinyl, cleaning isn't an option.
    You're supposed to listen once, throw away, buy new record....in that order.
    Looks like there is a RCM in your near future. Life just got more expensive! :D
    I didn't notice, do you have a cart in mind already?
  • MrBuhl
    MrBuhl Posts: 2,419
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • dpowell
    dpowell Posts: 3,081
    John, that is a beautiful piece of gear! I agree with others that it looks great in its current finish. can't imagine needing to change that. Put your coin into things that will make it sound its best. Also agree you need to ditch the center and get an in-wall. I tried phantom center with the 2.3TL's and it just isn't the same.
    The tonearm is out for delivery today...
  • Mike Reeter
    Mike Reeter Posts: 4,315
    John, your new table is surely a piece of Art. I'd say shine that bad boy with some Mothers Billet Polish.
    http://www.amazon.com/Mothers-05106-Billet-Metal-Polish/dp/B000COU7LG/ref=sr_1_1?ie=UTF8&qid=1453924431&sr=8-1&keywords=mothers+billet+polish
    This stuff is easy to apply and buff by hand, and leaves a beautiful finish.
    is mothers better than Fitz? I seen some amazing finishes with Fitz.
