Anyone play with their VTA?
  • StevieB
    StevieB Posts: 257
    edited February 2016
    I'm going to order the blocks soon and give it a try! Thanks for all the info.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • Dawgfish
    Dawgfish Posts: 2,554
    No problem! I'll be curious to hear your impressions.
  • gce
    gce Posts: 2,158
    I finally got the time to try this. I did the math and setup some gage blocks at nominal (90°), another set at 1° taller and another set 2° taller. First I played a recorded at nominal through 1 song. Then I raised it using the 1° blocks. Play the same song and could hear it opened up a bit, sounded clearer and fuller. Next I raised it with the 2° blocks. Even more clearer and the music filled the room more. Now I checked tracking force and it was off .2grams. then the overhang that needed a little adjustment.
    I'm now a believer. Sound it much better...thanks Dawgfish. Who would of thought! ;)
    Anaheim Hills CA,
  • Mikey081057
    Mikey081057 Posts: 7,127
    Check your azimuth adjustment as well. A tiny level that is less than 1g can be placed right on top of the headshell. This will indicate that the stylus azimuth position is set correctly left to right in the groove and can have a significant impact on SQ, soundstage and noise as well. Should be set to 0* Camera angle is showing it as off but from directly overhead it is dead center...
    Garage | Polk Monitor 5B's
  • Dawgfish
    gce wrote: »
    Good deal! The difference really is amazing! I was lucky that I had a couple of tables that allow quick and easy VTA adjustment so when I first read Michael Fremer's article, it was a quick and easy thing to try. I really didn't have anything to lose other than a few minutes of time. I tried it and immediately noticed the same things you described. Hearing is believing as they say. Happy listening!
  • Dawgfish
    I set my azimuth using a mirror underneath the cartridge resting on the record. I rotate the headshell until the cartridge and reflection are orthogonal to each other. All of my tables but one use removable SME style headshells that allow this. If the stylus is slightly bent, than you do the same thing above using the stylus and its reflection instead.
    Interestingly enough I was watching a video on VPI and it showed Harry Weisfeld setting up a VPI Classic. He set the azimuth by placing what looked like a straw or small wooden rod on top of the headshell and rotating the tonearm until the rod was parallel with the platter surface.
  • gce
    gce Posts: 2,158
    I'm unable to put a level on top of my headshell, it's rounded on top. I used the mirror method and all looked good. Now that it sounds better I'm going lower the arm back down 1/2° to make sure I have the sweet spot. Will it never end!
    Anaheim Hills CA,
  • Nope,,it never ends
