Anyone play with their VTA?
I'm going to order the blocks soon and give it a try! Thanks for all the info.
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable. -
No problem! I'll be curious to hear your impressions.
I finally got the time to try this. I did the math and setup some gage blocks at nominal (90°), another set at 1° taller and another set 2° taller. First I played a recorded at nominal through 1 song. Then I raised it using the 1° blocks. Play the same song and could hear it opened up a bit, sounded clearer and fuller. Next I raised it with the 2° blocks. Even more clearer and the music filled the room more. Now I checked tracking force and it was off .2grams. then the overhang that needed a little adjustment.
I'm now a believer. Sound it much better...thanks Dawgfish. Who would of thought!
Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Check your azimuth adjustment as well. A tiny level that is less than 1g can be placed right on top of the headshell. This will indicate that the stylus azimuth position is set correctly left to right in the groove and can have a significant impact on SQ, soundstage and noise as well. Should be set to 0* Camera angle is showing it as off but from directly overhead it is dead center...
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Good deal! The difference really is amazing! I was lucky that I had a couple of tables that allow quick and easy VTA adjustment so when I first read Michael Fremer's article, it was a quick and easy thing to try. I really didn't have anything to lose other than a few minutes of time. I tried it and immediately noticed the same things you described. Hearing is believing as they say. Happy listening! -
Mikey081057 wrote: »Check your azimuth adjustment as well. A tiny level that is less than 1g can be placed right on top of the headshell. This will indicate that the stylus azimuth position is set correctly left to right in the groove and can have a significant impact on SQ, soundstage and noise as well. Should be set to 0* Camera angle is showing it as off but from directly overhead it is dead center...
I set my azimuth using a mirror underneath the cartridge resting on the record. I rotate the headshell until the cartridge and reflection are orthogonal to each other. All of my tables but one use removable SME style headshells that allow this. If the stylus is slightly bent, than you do the same thing above using the stylus and its reflection instead.
Interestingly enough I was watching a video on VPI and it showed Harry Weisfeld setting up a VPI Classic. He set the azimuth by placing what looked like a straw or small wooden rod on top of the headshell and rotating the tonearm until the rod was parallel with the platter surface.
I'm unable to put a level on top of my headshell, it's rounded on top. I used the mirror method and all looked good. Now that it sounds better I'm going lower the arm back down 1/2° to make sure I have the sweet spot. Will it never end!Anaheim Hills CA,
