How much dampening foam for two SDA SRS 2s ?
[Deleted User]
Are you asking about adding Blackhole5 or the like to the back wall of the cabinet?Political Correctness'.........defined
President of Club Polk -
Yes, sir.
Ok, well BH5 only comes in one thickness. Sound Barrier comes in many, you'd want the 1.25" thick version. Most use 4" wide strips and install it behind the mid-drivers only.Political Correctness'.........defined
4" wide, 1.25" thick...by how long, and how many strips?Sound Barrier comes in many, you'd want the 1.25" thick version. Most use 4" wide strips and install it behind the mid-drivers only.
Please post your personal before/after experiences if you go through with it. Thanks TForan!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
So one 18x24 sheets is enough for both speakers or two sheets ?
One sheet is way more than you'll use. Your speakers have 4 mid-drivers (2 banks) each. Put one 4" W x whatever length it takes to span between the top of the top driver and the bottom of the bottom driver behind each bank.Political Correctness'.........defined
Thank you !
