How much dampening foam for two SDA SRS 2s ?
Should it be 1 inch thick ?
Thanks!
    F1nut Posts: 52,173
    Are you asking about adding Blackhole5 or the like to the back wall of the cabinet?
    F1nut Posts: 52,173
    Ok, well BH5 only comes in one thickness. Sound Barrier comes in many, you'd want the 1.25" thick version. Most use 4" wide strips and install it behind the mid-drivers only.
  • Schurkey
    Schurkey Posts: 2,122
    4" wide, 1.25" thick...by how long, and how many strips?
  • Nightfall
    Nightfall Posts: 10,083
    Please post your personal before/after experiences if you go through with it. Thanks TForan!
    afterburnt wrote: »
    Village Idiot of Club Polk
  • [Deleted User]
    So one 18x24 sheets is enough for both speakers or two sheets ?
    F1nut Posts: 52,173
    One sheet is way more than you'll use. Your speakers have 4 mid-drivers (2 banks) each. Put one 4" W x whatever length it takes to span between the top of the top driver and the bottom of the bottom driver behind each bank.
  • [Deleted User]
