Vinyl Question - Are Double LP Sets Better Than Single?
msg
msg Posts: 10,510
I'm seeing some albums listed available as both single and double LP sets.
If both are 180g, is one better (preferred?) than the other? And why?
  • hochpt21
    hochpt21 Posts: 5,423
    Probably one is a 33, and one is a 45. Most say the 45s are better because it leaves more space for the grooves. Or something like that.
  • Mikey081057
    Mikey081057 Posts: 7,127
    All things equal... there is no real measure of 180g vinyl.... some are better than others it probably has more to do with the engineering and production process of the vinyl itself... I read the reviews as much as I can to see if quality issues are there.
    Check this out
    https://www.youtube.com/watch?v=FyhfDEaz1Ug
    Garage | Polk Monitor 5B's
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ that was damned cool - I didn't know they were molded, thought it was all cut on lathes! ^^ Thanks for sharing!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Mikey081057
    RCA hired some babes back in the day yeah? That video is older than everyone here... except for @tonyb
  • chumlie
    chumlie Posts: 8,658
    hochpt21 wrote: »
    Until you have to get up every ten minutes to flip them. NO THANKS !!!
  • soundfreak1
    soundfreak1 Posts: 3,414
    HUH?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    msg Posts: 10,510
    chumlie wrote: »
    hochpt21 wrote: »
    Yeah, that part is a little interrupty. One of the reasons for my question - I like the tangible engagement but I also just want to listen to music with minimal interruption, especially with albums that are an experience. Maybe a common example would be Dark Side Of The Moon. You wouldn't want to stop that every few songs, right?
    Re: the 33 and 45 - yes, I've noticed this as well. Some of the doubles are still 33, but I do have one album set that's 45. I still haven't thought it through enough to figure out how that works. Seems at 45 the record content would be more spaced out? I don't know how this works or what factors into record quality or "analog resolution".
    Still gotta check out Mike's video link above! I'll do that when I'm looking for an excuse to procrastinate tomorrow.
  • PolkieMan
    PolkieMan Posts: 2,446
    Not quite! Hell to get old but better than dead!
  • soundfreak1
    PolkieMan wrote: »
    Ya but that's the only it's better than!. LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
