Burn In
machone
What do you think is the best way to burn in new components?
Leave music on continuous on low volume never turning it off?
Play music at regular listening levels for a several hours a day and turn off?
Does the volume matter?
Does it help to turn the system off to cool down and back on?
Is one source better than another?
The guy the rebuilt my Haflers recommended white noise as a substitute for music.
None of the above.
All of the above.
None of the above.
All of the above.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
1KVA Dreadnought
Marantz SA 8005
Sony PS4
I can hardly wait for the responses.
In before gatecrasher posts a picture of an Easy Bake Oven because that's still really hilarious. Again.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Just play your music as you normally would or if you want to speed up the process, put something on repeat when you're not around. You can write down the hours played if it helps you keep track. It'll take about 200 hours for those new crossovers to fully cook.
As for turning your rig on and off. I rarely turn off my gear as I see no reason to do so, but that's your choice.Political Correctness'.........defined
President of Club Polk -
Tubed gear included?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Tube power amps should always be turned off when you're not around.Political Correctness'.........defined
I mean preamps, cd players, etc that use signal tubes.
What about if that same piece also has a tube rectifier?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I leave mine on 24/7. They're not like power tubes, which can cause serious problems when they let go.What about if that same piece also has a tube rectifier?
I'm not 100% on that one. Ask Brock, he's the king of rectifier tubes.
Hey I wasn't going to post the Easy Bake!
lol
But what about nuking them in a microwave?
One of these original Amana Radaranges should do the job!
I would say any type of tube left on is going to shorten it's life. Now with that being said some vintage tubes can go 7000-10,000 hours since new.
I don't leave any tubes on while unattended for safety reasons and I rarely leave my super rare tubes on (idling) unless I'm listening to them.
A rectifier is a high voltage item and in many designs it takes the most punishment because of what it does. But, for instance, take a vintage Mullard GZ34 rectifier, they are almost impossible to kill. But considering their high price I still wouldn't leave tube gear powered up when not in use for long periods of time.
What I do is I decide if I'm going to sit down and listen and power things up for about 30-45 minutes before actually listening. I also make sure it's going to be more than a 15 or 30 minute session. Meaning I don't just turn the tubes on listen for 1/2 hour. turn them off for 3 hours and then come back, turn them on for another 30 minute session and so on.
On the weekends if I know I'm going to be home and listening (or atleast around the house-not outside) I'll power them up for part of the day and listen off and on as I go about my business.
Make sense?
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I just listen as I normally would, and let crossovers and drivers burn/break-in in their own time. I know others who play FM when not actually listening, and let it run at a lower volume 24/7 until the desired length of time is met.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I crack a beer and listen to the sound transform. Sometimes I leave it on while I'm home, and doing things around the house.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
As Dave mentioned, I'm one who puts the FM station on (classical) & let's things settle in.
