Burn In
What do you think is the best way to burn in new components?
Leave music on continuous on low volume never turning it off?
Play music at regular listening levels for a several hours a day and turn off?
Does the volume matter?
Does it help to turn the system off to cool down and back on?
Is one source better than another?
The guy the rebuilt my Haflers recommended white noise as a substitute for music.
None of the above.
All of the above.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
  • Schurkey
    Schurkey Posts: 2,122
    I can hardly wait for the responses.
  • Nightfall
    Nightfall Posts: 10,083
    In before gatecrasher posts a picture of an Easy Bake Oven because that's still really hilarious. Again.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,009
    Just play your music as you normally would or if you want to speed up the process, put something on repeat when you're not around. You can write down the hours played if it helps you keep track. It'll take about 200 hours for those new crossovers to fully cook.
    As for turning your rig on and off. I rarely turn off my gear as I see no reason to do so, but that's your choice.
  • Nightfall
    Tubed gear included?
    afterburnt wrote: »
    F1nut Posts: 52,009
    Tube power amps should always be turned off when you're not around.
  • Nightfall
    I mean preamps, cd players, etc that use signal tubes.
    What about if that same piece also has a tube rectifier?
    afterburnt wrote: »
    F1nut Posts: 52,009
    I leave mine on 24/7. They're not like power tubes, which can cause serious problems when they let go.
    I'm not 100% on that one. Ask Brock, he's the king of rectifier tubes.
  • Gatecrasher
    Gatecrasher Posts: 1,538
    Nightfall wrote: »
    Hey I wasn't going to post the Easy Bake!
    lol
    But what about nuking them in a microwave?
    One of these original Amana Radaranges should do the job!
    heiney9 Posts: 25,513
    edited February 2016
    I would say any type of tube left on is going to shorten it's life. Now with that being said some vintage tubes can go 7000-10,000 hours since new.
    I don't leave any tubes on while unattended for safety reasons and I rarely leave my super rare tubes on (idling) unless I'm listening to them.
    A rectifier is a high voltage item and in many designs it takes the most punishment because of what it does. But, for instance, take a vintage Mullard GZ34 rectifier, they are almost impossible to kill. But considering their high price I still wouldn't leave tube gear powered up when not in use for long periods of time.
    What I do is I decide if I'm going to sit down and listen and power things up for about 30-45 minutes before actually listening. I also make sure it's going to be more than a 15 or 30 minute session. Meaning I don't just turn the tubes on listen for 1/2 hour. turn them off for 3 hours and then come back, turn them on for another 30 minute session and so on.
    On the weekends if I know I'm going to be home and listening (or atleast around the house-not outside) I'll power them up for part of the day and listen off and on as I go about my business.
    Make sense?
  • westmassguy
    westmassguy Posts: 6,850
    I just listen as I normally would, and let crossovers and drivers burn/break-in in their own time. I know others who play FM when not actually listening, and let it run at a lower volume 24/7 until the desired length of time is met.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • mikeyb128
    mikeyb128 Posts: 2,885
    I crack a beer and listen to the sound transform. Sometimes I leave it on while I'm home, and doing things around the house.
    2 channel:
    Theater:
  • soundfreak1
    soundfreak1 Posts: 3,414
    Nightfall wrote: »
    lol
    WOW I actually used to sell those when they first came out. Damn I'm old.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • tonyp063
    tonyp063 Posts: 1,137
    As Dave mentioned, I'm one who puts the FM station on (classical) & let's things settle in.
