Modding RT25i crossover ?
heiney9
heiney9 Posts: 25,492
edited January 2016 in DIY, Mods & Tweaks
I've decided to mod the x-overs in my wonderful sounding Polk RT25i's. I have been wanting to do this for awhile now.
For the tweeter section they use an 8uF electrolytic and a 1.0uF mylar in parallel and a 2 ohm resistor in series.
I am having a heck of a time finding a 9uF capacitor other than Sonicap Gen I which makes the exact value. I have done Sonicaps before several times, so I was looking for something different this time.
As always these are in rotation in a secondary rig (might make a 3rd rig one day) so they don't get a lot of use. The idea is to keep the costs down. I'd like to keep the entire project to about $50.
Resistors will be Mills 5 watt 2.0 and 3.5 ohm $6 each crossover
27uF Low pass cap will be Solen PB $11 each crossover
I have some options as far as caps for the tweeter.
1. 9uF Sonicap Gen I $19.01 each crossover (over budget)
2. 3.3uF & 5.6uF Mundorf M-Cap Evo $11.23 each crossover
3. 2.2uF & 6.8uF Mundorf M-Cap Evo $11.88 each crossover
4. same values as above Mundorf M-Cap Evo oil $20.20 each crossover (over budget)
5. same values as above Clarity Cap ESA $23.00 each crossover (over budget)
6. same values as above Clarity Cap PX $11.00 each crossover
I am open to other suggestions. I've never used Mundorf and I know some have and sware by them. I am a big fan of Clarity Caps and already use the PX series in my 5B's. This is where I'm leaning, but I can be convinced to go another route.
So let's discuss.
    Now I remember why I hate doing crossover mods..................can't get ALL the stuff from one website....lol.
    Madisound has 9.0uF PX and ESA Clarity Caps, but don't carry the 27uF Solen Cap (only 25uF cap). Other places have the 27uF Solen but don't carry a 9.0uF cap.
    This means paying shipping twice.
    Really irritating. :#
  • westmassguy
    westmassguy Posts: 6,850
    9uf Clarity PX for the Hi-Pass and 12uf + 15uf Clarity PX for the Lo-Pass. Little over budget, but much better than Solens.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • lightman1
    lightman1 Posts: 10,797
    Where are you gonna mount the tube sockets?
    I suggest on the top for heat dissipation.
    Put up your dukes Brock!
  • Nightfall
    Nightfall Posts: 10,083
    lightman1 wrote: »
    Too much vibration to mount tubes directly in/on a pair of speakers, quit yer trolling! >:)
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,943
    I LOVE Mundorf caps in electronics, but I've never used them in a crossover. That said, I think they'd be worth trying.
    edited February 2016
    Yeah, been wanting to try Mundorf's in something. The oil ones have me a bit intrigued. I need to pull the x-overs again and familiarize myself with the real estate available to make all this work.
    Size does matter and I might be limited in that area as I'm not wanting to turn this into a big custom project. It seems like the reason I abandoned this before was cap size vs. the terminal cup and opening......lol
    Just a bit irritated I can't get the correct values of all the caps and resistors from one vendor.
  • soundfreak1
    soundfreak1 Posts: 3,414
    Used the munforf's in my 5jr+'s and worked fine. BTW if you would like I have a pair (I believe) of rt25 xovers you can have if you want to keep the originals intact.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Really, soundfreak1? That would be great. Are yours the RT25i or just RT25?
  • soundfreak1
    Just the reg rt's bought them at a garage sale some years ago when I had a pair in a 5.1 system. The cabs were for fobar I needed 1 driver for my good pair and still have all the others and the xovers I think just need to open the box and see them again. Pulled them out of the cabs and packed them away. Also have 1 driver and 2 tweets as I remember.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    yep just found the box! 1 mw5522 driver, 2 sl5507 tweets and 2 complete original xovers. Also (forgot I hade these) 2 vifa 804 tweets from a pair of time frames 450's I think.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    I love finding sealed boxes of stuff I forgot I had. It's like Christmas all over again. Too bad I can't use them. LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    Heiney9, I believe they are the same? Is it just the cabinets that differentiate them?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    I know what you mean, I found a pair of M5 passives I forgot I had as well as recently hooking up a pair of Pinnacle speaker's I haven't listened to in quite sometime.
    Let me peak at the crossover to familiarize myself again and then I'll let you know if I want those.
  • soundfreak1
    No prob. Have no use for them. There here if...
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    So, going through some old parts odds n ends boxes I found the caps I bought awhile ago for this upgrade. Clarity caps and Aeon caps for the low pass and Mills.
    Soundfreak1 if you still have those crossovers and they need a home, I'll take them.
  • soundfreak1
    That can work. Pm me your info. No charge for the xovers just cover the ship. They should fit into the P.O. 10.00 box. I will check as I think I have one to test fit.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    edited November 2024
    Not sure if I ever followed through with getting the x-0ver from Soundfreak1. I didn't run across them in the move.
    Finally all moved, have been since the end of September. My dedicated listening room is not even close to being set up, but now is the time to start working on it since the main part of the new place is all done and unpacked, etc.
    The basement is finished with a rec room and bar and a separate room for an office. I am getting my office rig up and running this long Thanksgiving weekend. One of the featured speakers will be the RT25i's after I rebuild the x-overs. I just bought a minty pair of x-0vers to work on so I can keep the originals if I somehow eff one up.
    Once I get back in the groove of soldering and methodically placing parts on a PCB, I'll upgrade the R200 crossovers.
    I bought the caps and resistors from Partsconnexion because of a 25% off sale. They didn't have the correct air core inductor. I have the schematic for the RT25i and steel laminate inductor I'd like to replace. The other inductor is originally an air core so I think I can leave it alone.
    My question is the schematic gives a dcr #, but the dcr rating on the Dayton air core inductors is 0.41ohms. I can get the exact 18 AWG 0.70mH air core, but the schematic shows 0.20ohm for DCR. Should I be overly concerned or it always the lower the DCR the better?
    Jantzen air core inductor same as above states DCR @ 0.40ohms
    Also, how the eff do you deal with the glued on parts? How to loosen the glue?
    VR3 Posts: 29,532
    VR3 Posts: 29,532
    Glue can use a heat gun
    Also the rti boards are very low quality with extremely thin traces.
    Be careful
    VR3 wrote: »
    So going to a smaller gauge of wire lowers DCR?
    One of the reasons I bought a 2nd set of x-overs was in case I eff them up. It gives more peace of mind. And these look to be untouched and I paid like $25 for the pair.
    VR3 wrote: »
    Originally when I started this thread I went with some cheap Clarity APW caps 9.0u, but read they weren't really that good.
    I couldn't find the 9.0u that you linked to anywhere. Forgot about HiFi Collective out of the UK.
    I ended up going with these as a compromise. I did some reading the Audionote electrolytic are very similar to the now defunct Black Gate caps. It fit, it was the right $$$ for this job and they get good press for how they sound.
    https://partsconnexion.com/audio-note-electrolytic-capacitor-6-8uf-50vdc-seiryu-series-non-polarized-radial/
    AND
    https://partsconnexion.com/claritycap-capacitor-2-20uf-250vdc-px-series/
    The PX Clarity's have always been a favorite.
    Also when did Mills resistors get so pricey!! A matched pair of 2u 5W are $14. They used to be $2-3 a piece.
    F1nut Posts: 51,943
    Dap lots of denatured alcohol on the glue keeping the glue wet. After 5 minutes it should peel right off.
    VR3 Posts: 29,532
    Bigger wire, lower dcr
    Don't recommend using electrolytic caps, even black note in speakers
  • bcwsrt
    bcwsrt Posts: 2,489
    I had to run and get some at the local Walmart because all I had on-hand was 70%, but @pitdogg2 used 91% isopropyl alcohol when he worked his magic on my RTA 15's. He applied like Jesse described and it worked great to remove the 30 year-old hot glue on those.
    Brian
    VR3 wrote: »
    Duh, 14 is larger than 18 AWG.......my brain wasn't working properly...lol
    F1nut Posts: 51,943
    Should have been dab, not dap.
    Just set-up (kind of crudely) the RT25i's. Qobuz through the Keces E40 integrated with dac (asynchronous USB) MIT AVt 3's.
    I forgot how damn good these sound!! Certainly worthy of a x-over refresh/upgrade. Amazing what incredible sound comes out of such a small box. These could literally fit inside the R200's and still have room.
    Feel like I'm in the front row of a Norah Jones concert.
    Crazy good.
    Going to get out my tube integrated's too.
    The question is do I spend an additional $80+ on inductors and better 9.0u caps. I feel like maybe holding back and going with something superior to the originals, but perhaps not top shelf is more rational. I could use the $80+ for part of a no holds barred upgrade for the R200s, which will always be the main speaker.
    I've got about $85 (including an add'l pair of x-overs) in them now.
    My thought was I could use the RT25i's in a 3rd rig. I purchased one of these to build over the Winter. I have an excellent minimalistic pre-amp to go with it. I think the RT25i's would be perfect.
    A beefed up Nelson Pass "Amp Camp Amp" (ACA MiniMax)
    https://diyaudiostore.com/pages/project-aca-minmax
    P.s. I finally have a large work space to actually do some quality DIY work. I am by no means an expert, but taking my time and with a little guidance I think I can do.
    VR3 Posts: 29,532
    The main issue is where you plan to put it. The crossover is going to take up substantial real estate in such a small enclosure
