These just in: Yamaha CA-2010 and CT-1010
gmjungbluth
I just found these on DC CL. In excellent if dirty cosmetic condition. The seller said one channel wasn't working. I am hopeful that a good cleaning of the pots and the preamp coupling switch will do the trick. I'll post updates when I have them.
HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100
Sweet.
Congrats. Eye Candy
Post edited by boston1450 onRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Not just eye candy -- nice stuff. Sonically, even by modern standards, I'd opine.
Aesthetically very nice too -- heck, Yamaha's basically gone back to those 1970s styling cues with some of their current products.
Hard to believe those components came from the same era as the AMC Gremlin and the leisure suit :-P
The coupler "issue" is endemic in those old Yamahas (as I'm sure you know). We'll all hope for trivial resolution to its issue. I think the "Class A" switches sometimes suffer from careless users who change operating modes with the amp on and running, too.
DSC_8057 by Mark Hardy, on Flickr
The left channel on my CA-1010 is out as well, somewhere in the preamp stage. Left channel works fine if I use it as a power amp. I'll get it to a tech one of these days, probably so I can sell it.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Update- cleaning was a success! I cleaned and lubed all the pots and switches and both channels work now. I want to clean the front panel and knobs before reassembling. Then I'll test it with some real speakers.HT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100 -
My CA1000 had a stuck Class A/B switch. They can get stuck in class A if switched back and forth with the power on. I picked up an upgraded switch from a Yamaha specialist on another forum. My amp has sounded great with every pair of vintage Polks I have tried with the Monitor 7's being my favorites.
Very nice!
Another update. The unit is all clean, inside and out and I was looking forward to testing it on my Klipsch CF-4s against my Fisher 500c. But then I plugged it in and didn't have the right channel!
So it looks like the preamp coupling switch in the back is still wonky. When I bypass the switch and run RCAs from the preamp to the amp jacks everything works fine. I may try to clean the coupling switch again but is there any reason why I couldn't just keep it hooked up the way it is now? I may make some short interconnects and stop worrying about the switch altogether.HT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100 -
You can use jumper in place of the switch. You could also Y off the pre-outs, and feed a separate power amp in another room.Home Theater/2 Channel:
dhsspeakerservice.com/
