Important Advice for SDA's with bolted on end caps
While inside my 2.3TL's today I discovered that every end cap nut was loose, so loose I could turn them by hand. To ensure this would not happen again I added a lock washer. I encourage all owners of 2.3's, 1.2's, 2.3TL's and 1.2TL's to check your end cap nuts because if they are loose, your speakers are leaking air. Those are the models I know have bolt on end caps, but there may be others.
It seemed to me that even with the nuts tight those areas could still leak air, so I made a gasket to go under each flat washer. I used some adhesive backed thin foam gasket material similar to the original driver gasket material. Using the flat washer as a template I cut the material with surgical scissors. I then used an X-ACTO knife to cut out the center. Make the center cut slightly smaller than the hole in the washer, that way it'll make a nice seal around the bolt.
Speaking of the stock driver gaskets. I've been saying for years that unless they are damaged there's no reason to replace them, especially if you have Larry's rings installed. What I found today re-enforces that. I had to pry the first driver loose and then had to push the rest out from the rear. I shake my head when I think about all those that went through the trouble of replacing perfectly good gaskets with Armacell or Mortite.
  • mikeyb128
    mikeyb128 Posts: 2,885
    I used mortite for the 8 inch driver upgrade on my lsi 15's. It's was too tight to push out with my hand, I had to use a pry bar through the hole for the binding post plate to crack it loose. That shite holds strong.
    2 channel:
    Theater:
  • westmassguy
    westmassguy Posts: 6,850
    Makes sense. A couple of decades of expanding and contracting due to temperature and humidity. Check your crossover mounts too. I've found many SDAs with loose cap screws.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Thanks for the tip. I checked mine and they are still tight. When I replaced the end caps on my SRSs and 1.2TLs, the end cap nuts were still tight after 20+ years.
    I can see where vibration, moving the speakers around, and expansion/contraction due to humidity changes might loosen the nuts over time.
    I'll have to respectfully disagree here. I noted audible and measurable differences among original foam seals, Mortite, and Armacell. Mortite was recommended by Matthew Polk as a higher performance alternative to foam seals.
    My comparisons of original seals, Mortite, and Armacell are here:
    http://forum.polkaudio.com/discussion/123136/sda-driver-seals-original-foam-vs-mortite-vs-armaflex-foam/p1
  • xsmi
    xsmi Posts: 1,804
    SRS 2's also have bolted on end caps.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • oldrocker
    oldrocker Posts: 2,590
    Good info, TKS
  • PolkieMan
    PolkieMan Posts: 2,446
    I will check mine when I get home tonight thanks
  • Schurkey
    Schurkey Posts: 2,122
    nbrowser wrote: »
    Personally, a very little dab of Blue (Loctite 242 medium strength) threadlocker on the threads of the studs the nuts thread on to might stop them from backing off...but just a small little dab, and no....don't use the red version....seriously...don't use the red stuff...trust me...red stuff will cause the studs themselves to unscrew frothe end caps.
    First Guess: The nuts are not "backing off" except perhaps AFTER they become loose due to the changing thickness of the wood cabinet materials due to humidity variation or other causes.
    Gluing the nuts in place won't help if dimensional changes cause the fastener preload to "go away". Gluing the nuts will keep the nuts secure, but doesn't assure fastener preload when the wood changes thickness.
    Great...something else to deal with on my SRS 2 p/b speakers. I swear that someday I'll get back to working on them.
    F1nut Posts: 51,962
    The end caps in question are wood veneer over MDF, they are not subject to dimensional changes. If your end caps are the all wood version found on the SDA SRS model they may be subject.
  • aprazer402
    aprazer402 Posts: 3,402
    That is interesting. Are there any other vintage Polk models other than the SDA SDS, I'm assuming you're referring to the very first SDA SRS models, that used all wood instead of veneer?
  • waxman
    waxman Posts: 125
    +1. Found the same tonight when I started the surgery on my 2.3TL's. Half of the end cap nuts were able to be loosened by hand. Was just going to use lockwashers but your +gasket idea makes sense, need to see what I can find.
    F1nut Posts: 51,962
    aprazer402 wrote: »
    That is correct.
    I'm not 100% sure, but I think the SDA SRS 2 end caps are all wood. Hopefully, Schurkey can verify that.
  • vcwatkins
    vcwatkins Posts: 1,992
    aprazer402 wrote: »
    That is correct.
    My '86 SRS2's were jointed wood caps.
  • Schurkey
    vcwatkins wrote: »
    aprazer402 wrote: »
    That is correct.
    My SRS 2 p/b have laminated wood top caps. I assume the bottoms are also laminated. Mine show minor splitting at the "seams".
    msg Posts: 10,460
    good heads up here, Jesse. I'm curious to check mine out, since I've had that mystery issue with absolutely zero bass. granted the crossovers need work, but wouldn't think to the point that the speakers would be completely empty.
