Bottlehead Crack
I have extra volume pots here that I will ship you - you just pay shipping. They are the ones that Bottlehead uses in their current production units. Looks like the same knobs so I'd guess the shaft size is the same so the knobs should fit. I'm not sure what size the cutout in the plate is, not sure if it has the hole for the positioning tab will be correct.
The only volume pot that I've used that is economical and works very well is the Alps. The issue is that the solder points are very tiny. I'm a pretty decent solder monkey and I hate working with those Alps pots.
Your best bet is to cruse on over to the Bottlehead forum and ask that bunch. The guys that designed that unit are still there and can give you very good advice. The community there is wonderful and you may find someone there who has done exactly what you want to do with this unit.Aaron
Enabler Extraordinaire -
Hmmm - excellent thank you! I will check in with the Bottlehead forum.
Do you think the current production volume pots would be an improvement over the ones the stepped attenuator replaced? Very generous offer - I appreciate it.
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
These current ones are not steppers. They are the old style swipers in a can. The cost is reasonable! Whether they sound better or worse I can't tell you. I do know you won't get any noise as you change volume. I'd still check in with the BH crew and ask what they would recommend. If you do want these - they are the stereo pots so they have 6 connectors each - 2 layers. Just use one layer per side, they'll work just fine.
Aaron
WIll Do! Listening to that bad boy right now! For the money, it's shockingly good.
That's a nice build. Auricaps are very good reasonably priced caps. I used them in a project once upon a time.
Bottlehead is short on cost, long on sound quality.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
HEY RICHY!!! Going to Axpona this year?Aaron
Hey Aaron! Yes! Carl, Dan and Ed Savinon the SRT Speaker King are threatening to show up again too.
I have to get cracking on my new turntable!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Sweet! If you don't mind me tagging along again let me know which day you guys are going. I've got the three day pass so anything will work.
Ya...did you get the wood? I've lost track.Aaron
Tagging? You can take the lead! Maybe Doug can make it too. Like last time, we will probably do all day Friday and chill at my place Saturday. Whine, I mean wine, brew and tunes. Dan is quite the wine connoisseur. He and Dana get into that wine tasting thing, share favorites. Dan usually goes back to the show Sunday before flying out.
Yes, I have wood! No time though...finished Carl's Amanaero USB module with the Hermes Cronus today so maybe...
On to further Crack changes - get the 6.3v adapter from the Lowther_Club (didn't find it on dbay or fbay...something in between) to go from the 12AU7 to a 6SN7. It'll take three or four weeks to get here from China but it works perfectly. Don't forget to get a 6SN7 tube from somewhere also.
Horry bratcrap! Nice....very very nice!
Do you mean....if I got the speedball mod then I can just drop this adapter in the tube socket and play with 6SN7 tubes?Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
Wee Wee! Just insure you get the 6.3 volt version. I have a 12v version - no worky.
Lother is the all black one. The other one is also from Epray and appears to work just as well but it has an "ugly" factor about it.
Aaron
Here's the difference between connections on the new stock pots and a used Alps.
Aaron
Technically, a ring terminal potentiometer versus a pcb board mount potentiometer that something bit the shaft end off....
everyone's a critic...
I bend the ends over so I can keep the wires on while soldering... and I was hungry.
Aaron
Da BAC plate is painted... BEWARE THE BAC!!!
Aaron
Some intelligent individual made sure to remind me to scrape some of the paint off at grounding locations. I suggest this to you.
Nice choice with the black
Does it have some sort of sparkle/fleck to it or is it just the pic?Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
I gots a new "trick". It's hard to paint stuff in the winter and get it to dry. Some of these nutcases put their stuff in a toaster to cure it. I have one of those oil filled radiator style room heaters. So I heat the plate by laying it on top of that heater and I'm using the hammered finish paint - for some reason the heat just give it a nice matte finish and still leaves a shine. Paint and heat....paint and heat. I only painted one side so I should be ok with the ground.Aaron
Nice! I use oxy/acet torch to dry wet paint!
No need to scrape or spotface! Use star washers!
Crack ****...
Wiring to start today.
Aaron
Dems black sockets is shweeeeeet!!!
Transformer cover?
Explain the two snare drums by the power socket.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Transformer cover is hammered copper paint cured with heat.
Snare drums are Cap1 and Cap2 - just bigguns. I'll tip 'em with some film underneath. Cap3 is the big 220uf Solen film cap.
The blue tape is holding the screws for mounting the choke - I planned a bit tight without needing to.
And those black sockets - damn....everyone should use those!
Aaron
Cool. My phone made it look stock silverish.
I think your the only one crazy enough to even try black sockets......
What's with that headphone jack?. Just decorative? Massive...Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Bling....had that thing with the holes in it sitting around here for years. It fits. That's just a Neutrik jack so it really has nothing to do with the jack at all.Aaron
I thought it was another tube socket.
Enough for one day...
Aaron
Nice look! Love the on/off switch!
That thing with holes....I'm wondering if an RC car in da hood is missing a wheel.
It's cryin' time...
Down to pretty much the last 4 solder points before testing (speedball to wait until this test ok). I'm reusing the big blue Clarity caps from Crack #1. Lead for the cap breaks off...CRAP!! Flexed too many times. But... if that had happened after I had it done - CRAP x2!!! So, I've reordered... gotta wait...again.
Until then - Crack ****..
volume and bling painted to match the xformer cover. Not sure I like it but it'll do.
Bottom - prior to output caps. That black square stuff is just sound damping material. Takes some of the boing out of it.
Aaron
Well....in my angst and disappointment over the cap failure I forgot I had the original caps to test with. So... IT FRICKIN' WORKS!!!! Maybe I shouldn't sound so surprised...
Had some very strange voltage readings on initial power up....then I put the tubes in and they dropped to normal. JEEZ!!!
Aaron
Shweeeet
You need to make a bronze badge of yourself.
Well??....how's she sound and what can are you using?Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
