Male xlr to rca cable
daboyz
Need a male xlr to rca cable. Not looking to break the bank just something good for the buck.
Can't you just use an RCA-RCA cable ? Going balanced to RCA negates the benefit of balanced imho.HT SYSTEM-
lsi 9's -
Well, hunted around but only have XLR to 3/8 so far...
Going from XLR output to RCA input is tricky. There are three (or 4) types of XLR outputs and one adapter won't work for all of them.
I'm going from a Dared to the Behringer DCX2496. No choice at this moment. -
You can purchase single ended (RCA) adapters with an XLR cable
http://www.neutrik.com/en/accessories/circular-adapters/na2fpmm
txcoastal1 wrote: »You can purchase single ended (RCA) adapters with an XLR cable
That would be smart. Thanks! -
I got mine from a seller on Audiogon. I can't remember his name, use the search feature and you can probably find him.If you can't hear a difference, don't waste your money.
I have used a set of xlr cables with one end cut off and the RCA terminator soldered on for my Rane external xover for some years. No apparent negative issues to report.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I'm understanding that they're coming out wit a x'over box that will eliminate bi-amping and the need for the Behringer so I won't need the adapters. Thank god I didn't buy any.
