SDA Wooden End Caps or Re-Veneer Suggestions
2
  • nikolas812
    nikolas812 Posts: 2,915
    Just let me know! I'd be happy to do them.
    Nik
  • leftwinger57
    leftwinger57 Posts: 2,917
    Sorry to get back to you so late. Yes mine were deeply water stained and I'm guessing some sun bleaching also because there was little of the original varnish left. The directions on the axolic acid box was to do an entire deck surface. Not a good idea for the end caps they would warp by the time it dried2sszg9ng0znq.jpg
    . F-i NUT helped me through this process of mixing the acid w/ water to a paste consistency, apply to effected areas then let dry. Clean up the dried crystals ,tack cloth them, some minor sanding and they were ready for the stain. The picture on the 1st page was w/o the clear poly and once that was done a nice sheen was laid down
  • teekay0007
    teekay0007 Posts: 2,289
    I feel I'd be doing a disservice to Larry, our own Toolfan66 (of "Larry's Rings" fame!), if I didn't post a few pics of my SDA-1Cs. He did an incredible job, the finest I've seen, on their end caps prior to my acquiring them. The originals were replaced with stained hardwood ones.
    They're still in pristine condition and would work, style-wise, in just about any room with pretty much any décor.
  • Those really are magnificent. He did a wonderful job. I like the dark stain.
    Harry
    Harry / Marietta GA
  • Conradicles
    Conradicles Posts: 6,339
    Those look superb!
  • teekay0007
    edited January 2016
    Where did you get that rack? I really like the looks of that too.
    gudnoyez Posts: 8,161
    teekay0007 wrote: »
    Terry finally I get to see those 1C's, I was wondering if pictures of those beauties were ever going to surface. I tell ya when we hooked up for breakfast last fall me and Skyler would of loved to have checked them out, had we not had time constraints. I see a lot of sexy end caps here and those piano black tops of the OPs are also drop dead gorgeous.
    Here are the end caps that Ryan ( ZLTFUL ) did on my Z edition 2.3tls. Just took em Christ I had to tiptoe this I'm 6'4 these 2.3tls are some pretty big speakers.
  • Conradicles
    teekay0007 wrote: »
    I think Walmart online. It is currently in my media closet holding all of my H/T gear.
  • teekay0007
    gudnoyez wrote: »
    Steve, those 2.3TL end caps look great! Ryan did a nice job on them. I'm glad you were able to pick them up last year. I'm hoping they are bringing Bieber, Manilow and Newton-John right there into the room with you, like you wanted! >:)
  • teekay0007
    teekay0007 wrote: »
    How's the quality on it? Good, solid stuff? Or, does it have 'Walmart' written all over it? Do you have a model number? I see they sell a ton of different ones.
  • boston1450
    boston1450 Posts: 7,758
    Naked :)mvi78vk1jjn5.jpeg
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • westmassguy
    westmassguy Posts: 6,850
    boston1450 wrote: »
    I'm offended
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Conradicles
    Still trying to decide what to do to my SDA SRS 2 end caps. Anybody know a good source for real wood caps, kind of like esoteric cutting boards? I know real wood can crack, but still it looks amazing.
  • gwg_97
    gwg_97 Posts: 332
    I've done both veneer and solid wood. Solid wood is a lot more work and I actually like the veneer better. Photo of hand rubbed raw walnut veneer on 1Cs. I used teak oil.ko4x9w2rzjbh.jpeg
    I really like the finish.
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • ptrooper
    ptrooper Posts: 501
    tops to my 2.3s's.....west australian timber,very hard wood "Marri"b8y9roovx89n.jpg
  • Conradicles
    Man both of those are inspiring!
  • TCK
    TCK Posts: 231
    They all look great, makes me want to redo mine. My 2Bs look good, just a little dull. How hard are those caps to get off and what method(s) did you use?
    - SDA 2B (1989, Oak Tops, 194s, Spikes)
    - Monitor 7B (1982 Peerless, Sonicaps, Mills, BH5, JB Welded, Binding Posts)
    - (2) SVS SB12-NSD (Flat Black)
    - SVS SB 3000 (Gloss Black)
    - Pioneer SC-1222K AVR
    - Marantz MM 7055 (5 Ch Amp)
    - Pioneer PD-D6 SACD Player
    - Marantz NR1403 AVR
    - Sony UBP-X800M2 (4k Blu-ray)
    - Sony UBP-X1100ES (4K Blu-ray)
    - Adcom GFA 555 Amp
    - Monitor 5 (194s, Side Surrounds)
    - Monitor 5Jr+ (194s) {Storage}
    - LG OLED65CXPUA (4K OLED TV)
    - LG 55UN7300PUF (4K HD TV)
    - RT35i (Cherry)
    - (2 Pair) RT25i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
    - F/Xi A4 (Rear Surrounds)
    - RT25 (Rear Surrounds) {Storage}
    - Audioquest Interconnects
    - Blu-Jean Speaker Cables & Interconnects
    " But boy do I remember the strain of her refrain " LG
  • ptrooper
    ptrooper Posts: 501
    edited March 2017
    I did the 2.3's and SRS by Removing the top drivers and PR ,undoing the 8 nuts internally and the caps come straight off,Everything on the caps was removed and reused on the new ones!
    The SRS caps were done with another Australian hard wood "jarrah"q7g8k6k7jt8x.jpg
  • monepolk
    monepolk Posts: 1,154
    Did you do these yourself?
    pitdogg2 Posts: 27,033
    edited March 2017
    never thought I'd say this to a dude... that's some sweet wood. ^^^^^^
    xschop Posts: 5,138
    Those are beautiful.
    F1nut Posts: 51,747
    TCK wrote: »
    2B end caps are glued and stapled. You have to carefully pry them off, start at the rear.
    F1nut Posts: 51,747
    ptrooper wrote: »
    I like!
    EndersShadow Posts: 17,704
    gudnoyez wrote: »
    Those 2.3TL's have been around a bit. They started with @trav0810 who brought them to my house and swapped them with @ZLTFUL for a set of upgraded RTA15TL's, and then obviously they went to you.
    Its fun to know see some of the provenance of the speakers around here, though none can compare to the Threshold amps of @txcoastal1 which were owned by Matt Polk
  • TCK
    TCK Posts: 231
    Thanks @ptrooper , nice work, takes them to a new level of cool. I wish my ends were that easy, looks like mine are the "pita" kind to get off
    TCK wrote: »
    Thanks @F1nut , that would have been quite a surprise. Good to know.
    Great to see all the exterior mods.
    - Adcom GFA 555 Amp
    - RT35i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
  • Conradicles
    ptrooper wrote: »
    @ptrooper These would match my man cave totally! Link to where you got them?
  • ptrooper
    ptrooper Posts: 501
    @conradicles.
    woodworkings.com.au
    08 94598115
    15-17 carole rd,Maddington Western Australia 6109
    Photos never show justice,,these look fire trucking hot in person.
    F1nut Posts: 51,747
    edited April 2017
    NM.....didn't see his response.
