There's a monster behind my couch
Been toying with the idea of moving my PB13 Ultra behind the couch and did it...Not being sure how it would work out. It is interesting... I set the phase to 180* and re ran Audessy. The levels are fine as the Ultra has plenty but when it thumps the couch, it feels like you are being pushed off... (exaggeration). Has anybody tried this... are they any tips to make this good before I move this big SOB back?
Garage | Polk Monitor 5B's
    edited January 2016
    I've heard of people putting one back there and running a second somewhere else in the room. Supposed to BLOW it out your x%x! Thought I'd censor myself before Vanilla got me! lol
  • mikeyb128
    mikeyb128 Posts: 2,885
    edited January 2016
    I put one of my ultras behind my couch and the other in the front corner of the room. It was pretty cool for a while, but I couldn't get it right. I had anti-mode at the time, and it did a great job with the eq, In the end I could always localize it, it's just so big, I found at times it over
    Powered the front one. I now use both up front near both my mains. And guess what? They still vibrate the back of the couch being up front. It blends better, sounds cleaner, I like it better.
    I tried it a dozen different ways, facing the back of the couch, facing the rear wall, side ways, then my back started to hurt, and I was sweating. So I moved it back up front, and there they stay, they are too big to be moving around the living room. Those ultras are sweeet. You should buy another one :smiley:
    2 channel:
    Theater:
  • Mikey081057
    Mikey081057 Posts: 7,127
    The only negative about the Ultra is that experimenting with it is difficult due to it's size and weight.
  • Mikey081057
    I put it back to the front... Didn't care for the behind the couch placement...not worth the effort imho
  • afterburnt
    afterburnt Posts: 7,892
    I did that and I can no longer father children.
  • Mikey081057
    It is a BIG MFer for sure
  • westmassguy
    westmassguy Posts: 6,850
    Mine's tucked in the corner behind the couch. I like the free rumble massage, reminds me of a cheap who-tel
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    A monster behind your couch ??
    Whats Russ doing behind your couch ? :p
  • Mikey081057
    tonyb wrote: »
    He was looking for a fresh piece of carpet to scoot on
  • lightman1
    lightman1 Posts: 10,800
    tonyb wrote: »
    I have one bad roid day at your place and you won't let it go.... :#
  • Mikey081057
    But the chili was good no?
  • lightman1
    Si! Gotta make my way over there before this gig is over.
    Say what ??
    You had the balls to feed Russ chili ?? Now that's livin' on the edge pal....way out on the edge. :)
  • MetropolisLake
    I experimented with this, ported subs sounded pretty wild back there but I moved my sealed 18's back there and they sounded like crap. Really weird.
  • classic carl
    I had a Polk PSW111 behind the couch in the living room for a while. I never sat on the couch though. I'm usually in the kitchen when that system is playing. It did resonate all the ductwork in the basement though. I just sold the sub because that 2 channel system didn't really need one.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
    Teac R-919X ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
