Record Cleaning Fluid Recipe? - RCM
MrBuhl
Hi all -
Anyone care to share a magic elixir that you've been using for a vacuum based RCM?
Hoping to not have to store Tergitol in a fridge, etc as my RCM (Nitty Gritty MiniPro1) has a reservoir for fluid that certainly wouldn't be refrigerated and sits for relatively long periods of time.
Currently using Pure2, which allegedly doesn't need a rinse - so the lower maintenance the better.
Many thanks!
Many thanks!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
I use MoFi PLUS Enzyme Cleaner - on old records then VPI cleaner which I didnt know you need to refrigerate for long storage until you mentioned it....then I use distilled water to rinse..can't skip the rinse ED
Have tried some MoFi ONE which I think doesn't need rinsed but I still did..
Have not tried home formula's!
lots of different stuff on Music Directs site and here is one to check out
http://www.musicdirect.com/p-7296-mobile-fidelity-super-record-wash-32oz.aspx
I like to do a rinse with clean distilled water no matter what I use to clean.
I just keep my bulk Tergitol S3 and S9 in a dark spot in the basement. IIRC sunlight is the worst thing for it. I've never refrigerated the mix. You can also buy some great products. Tergitol works great and is very cost effective provided you can purchase it in small enough quantities.
I read there was a single Tergitol that embodied the S3/S9 combo, perhaps it was Ken that posted that here once upon a time?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I just use the Pure 2 without a rinse.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
SCompRacer wrote: »I read there was a single Tergitol that embodied the S3/S9 combo, perhaps it was Ken that posted that here once upon a time?
That sounds familiar to me as well.
I remember reading and posting in a couple threads about the Tergitol record cleaning formula. We need to find one of those and see if we can get it made a sticky, as the topic comes up every few months.
Wristwatch--->Crisco -
I use MoFi PLUS Enzyme Cleaner ....then I use distilled water to rinse..can't skip the rinse ED
here is one to check out http://www.musicdirect.com/p-7296-mobile-fidelity-super-record-wash-32oz.aspx
Hahahaha!! Calling me out on the rinse Darryl! I Love it! Lazy I guess!
Good suggestions - thank you - and a bit more cost effective than the Pure2 as well.
Paul that's exactly what I've been doing - Pure2 no rinse, but my machine cleans both sides at once, so a rinse would mean flipping the record too (oh, the horror!)
Scomp & Strider - the Tergitol combo sounds interesting - we may have to summon up @KennethSwauger and see if he can help us! If it doesn't need refrigeration, I'm game to try!
Thanks all for the ideas so far!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
This is where I bought my Tergitol, at Ken's recommendation:
http://apps.bnt.com/ecom/catalog/product_specific.cfm?ClientID=15&ProductID=17376Wristwatch--->Crisco -
^^ thank you! Thats more reasonable than I expected! ^^VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
Here's one of the threads I was thinking of:
http://forum.polkaudio.com/discussion/67762/record-cleaning/p1
It has Ken's recipe for the cleaning fluid. I never got around to mixing a batch myself.Wristwatch--->Crisco -
I believe you can use Tergitol S7, which is a blend of S3/S9 if you use this I imagine you would use 4 teaspoons in a gallon of distilled water. Just keep in a fairly dark place, no need to refrigerate.
Since I use a steam pre-wash, I followup the cleaning with a steam rinse and have great results. -
Outstanding gents!! Thank you all so much!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
