AMP FOR SDA SRS 2.3
Krell KAV 2250 OR ADCOM 5802???
Have ran an adcom 5500 and carver m-1.0t powering infinity cresendo's ... liked the carver sound better then the adcom.
I am assuming the Krell will have a more natural sound to it, however I do like the fact that the adcom 5802 is set-up with bi-wiring outputs.
Any thoughts on this would be greatly appreciated!
  • Schurkey
    Schurkey Posts: 2,122
    edited January 2016
    5802 will require the isolation transformer in the SDA interconnect cable, or a jumper wire between the negative terminals. I don't know about the Krell.
  • Schurkey
    edited January 2016
    double post. Sorry.
  • Speaking of .... just ordered up the avel 800VA XFMR, enclosure, dynomat, copper foil tape, etc ... Going to see what kind of DIY damage I can do.
    Thinking I'll just go with the dual Carver M-1.0t amps as they are just laying around at the moment. If only I could get the MKII-0002 mod. done! Seems like there is a waiting list of 15 months+. Currently have some crossover issues, so they are getting stripped out and sent in for complete re-work/mod. up grades.
    F1nut Posts: 52,101
    It's Dynamat and hopefully you got the Xtreme version. Do you plan on using the Dynamat and the copper foil tape in the enclosure?
  • Yes, the extreme version of dynomat,lol. Sorry. Correct, copper foil and dynamat extreme for the enclosure ... perhaps "speakOn" plugs??? Or? Getting rid of the pin/blade socket on the speakers and changing out the binding post while I am at it.
  • I am open to any and all suggestions!!!
  • warren
    warren Posts: 756
    Carver M-1.0t amp, paired with a Carver pre amp C-2 all stock, all good..
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • Funny you should mention, Warren!
    I've decided to take the two Carver M-1.0t amps and run vertical bi-amp with bi-wiring. If I have it right, it's one dedicated amp to each speaker, bi-wired.
    Then all that should be left to do is get the MKII opt002 upgrade mod to both amps. Am on the waiting list ... 15 MONTHS LONG!!!!!
  • I do have a C-7 preamp, but ... am sure there is something better for a reasonable price. Would like a center and sub output. I know the C-17 has a center channel, but no sub.
    All in due time I suppose ... ... ...
