Lsi9
11tsteve
11tsteve Posts: 1,166
edited January 2016 in DIY, Mods & Tweaks
Well, a couple of months back, I bought a pair of Lsi9 from cstmar01 for a very nice price. They have some cosmetic issues, which I knew about, but sonic-wise are fine for stock. In fact, I put them into the system, and they mesh very well with what I have going on. Everything I have for speakers are updated vintage, and I wanted the Lsi9 to give a more modern speaker design a listen.
Compared to the rest of my stable (all of which I enjoy for differing reasons), the presentation and pinpoint detail of the Lsi9 is quite pleasing. They just slid into my system, and I have done nothing but enjoy my time getting to know them.
So, I have decided to move forward and put some work into them. Crossovers will be modded, and I spent the afternoon removing the side panels. These are second gen and glued on, so it was some work, but nothing horribly difficult.
I feel overwhelmed, more so than previous projects, just because these are not quite as straight forward a project as, say, 5 Jr+.
I will re-veneer the side panels (thinking burled something, or tiger striped maple), and I would like to refinish the cabs. The piano finish has some damage, and needs to be either repaired, or completely redone.
Right now, my main two questions are...
How to remove the glue from the cabs and side panels.
And the best way to remove the original piano black finish?
I think I want these to be my main speaks for a while. They really trip my trigger and work well with my McCormack... so I want to do these right.
Steve
I was thinking Sonicap Gen 1's and Mills for the crossovers. Anyone had better luck with others?
Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2
Post edited by 11tsteve on
  • 11tsteve
    This morning, I ordered the veneer for the side panels. I have three sets of speaks done in varying forms of oak, and I wanted something different for the Lsi9... something figured. After spending a few hours at Veneer Supplies, it came down to burled walnut, burled white oaf, and burled maple. I chose the maple.
    There is not much paper backed figured veneer, so I bought a lot of 9 sheets of raw veneer. This will be my first foray into using raw veneer, so if anybody has any tips, they will be appreciated.
    I still haven't come to a conclusion about the crossovers. By the time I purchase everything I need for a DIY, I am getting close to the cost of fortress level crossovers from VR3.... the thing I am caught on is the low end. I would really rather add the film caps instead of a bypassed electrolytic. I have been studying Ray's thread on his Lsi9 mods, and will most likely go that route.
    So many decisions.
    This weekend will be spent stripping and prepping the side panels.
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    Been pretty busy of late, but I found some time this weekend to finish stripping the veneer from the side panels. All in all, it went much better than stripping the vinyl from the RTA 11T's or the 5jr+'s.
    I have today off due to weather, so I get to start sanding the panels down, and I have applied veneer softener to the sheets I have decided to use. k8higg40a5kz.jpg
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    Also, as a side note, I used Goof Off super glue remover to clean up the residual adhesive from the side panels, and I must say it seems to be an excellent product, dissolving the dried glue in a matter of a couple of minutes. I scraped it off with a sharp putty knife, and it seems to leave nothing behind.
    http://www.goofoffproducts.com/product/pro-strenght-super-glue-remover
    Polk Lsi9
    Keces DA-131 mk.II
  • mikeyb128
    mikeyb128 Posts: 2,885
    Very cool. I've used goof off before with great results, seems to remove any kind of glue residue with ease.
    2 channel:
    Theater:
  • 11tsteve
    edited January 2016
    New sidenote to my audio journey. My McCormack DNA 0.5 will be making the trip to SMc Audio for the Gold Standard upgrade.
    When they are finished, about all of the original amp that will be left is the chassis, the transformer, and the output boards. All new everything else, including the main board.
    Turnaround should be 3-4 weeks, so hopefully I can get this Lsi9's put back together in that time.
    Not to mention, my ears will probably be bleeding by then from listening to my old NAD 2150....
    I am experiencing difficulties with the veneer. I believe I didn't initially apply enough of the softener, and so I am going through a second process of trying to get the veneer to be more pliable.
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    anonymouse wrote: »
    When I did my CRS+ in raw walnut veneer, I used normal wood glue, covered the veneer fully with a thin but adequate layer, let it dry to just tacky, and then ironed it on with a regular clothes iron with a barely damp cloth between the iron and the veneer. This worked really well. I was even able to do rounded corners easily with this technique. Over 4 years later, I have not had any separation problems with the veneer. I would try this technique vs. your softener technique.
    anonymouse wrote: »
    Also, for your crossovers, splurge on sonicaps for the highs, go with daytons for the lows. You will be happy with the results.
    Thanks very much for the tip! I had reapplied the softener a few days ago, and I had much better success with the sheets being pliable this morning. I barely misted a towel this morning, applied the glue (I have a veneer glue), let it set just a bit, and tried the iron. I worked well in getting the sheet flat and getting the veneer to bend around the curve. The panel is currently in clamps, so well see what happens.
    I am starting to wonder if maybe contact cement might be better for this project though. The positioning of the veneer is not critical in this case, so the disadvantages of the cement aren't a big deal.
    I did order crossover parts, Sonicap Gen 1 for high/mids, Mills 12v all around, and 2 Solen 130 uF for the low pass. I also ordered some Derlin and Cardas QE solder.
    All I need is some good hookup wire, but I don't really know what I want.
    I am going to try a mix of DarqueKnight's thread on modding, and attempting building a new crossover using point to point wiring in a VR3 style.
    I built entirely new crossovers (with Trey's help) for my Infinity Rsb, and it was very challenging, but the results were very satisfying. The Lsi 9 will be a bigger challenge. With the Rsb, the 10 inch woofer cutout made design and installation was easy.
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    progress. I haven't decided what route to go with finishing though....h3pjg0njg6xk.jpg
    Polk Lsi9
    Keces DA-131 mk.II
  • 11tsteve
    I started getting some color into the grain of the panels today, using 2 Minwax products. First a pre-stain treatment, and then I am using a natural stain.
    I have a compare picture to start with, and more as I get further along.
    The pre-stain went on, was allowed to sit for an hour or so, and then the first application of stain. I got all four done with the first round today, and lightly sanded, ready for the second round tomorrow.
    While they were drying, I got a start on the crossovers. I am using Derlin for the boards, which I cut to size using the dimensions of the stock board. I used my Rockwell oscillating multi-tool, which went smoothly. I just had to sand the cut edges a bit, as the tool burrs the plastic a little.
    I did a mock up, drilled for my zip ties, and got one about ready for soldering in the morning. Should have put a quarter in for scale to give an idea of those BigBoy 130 uF's. That board will somehow be attached to the bottom of the speaker cab as I did with my Infinity Rsb's. I just don't yet know how.
    I drilled and tapped the stand-offs on the stock backplate, and have some 8-32 ReadyRod I am going to use to mount the mid/high boards, a la Fortress mod. I wanted to possibly build a new backplate, using some 1/4" Derlin and 1/8" brushed aluminum plate, and also drop one set of binding posts in that process( I will never bi-amp these), but I am running out of allotted time. That is something I can still do later.fik147vhyh41.jpg
    Polk Lsi9
    Keces DA-131 mk.II
    F1nut Posts: 51,766
    I wish I'd seen this earlier. Since you are not adding color there's no reason to use a pre-stain or clear stain at all. Just finish them with the clear coat of your choice. If you have spray equipment, nitro lacquer would bring the grain out beautifully.
  • 11tsteve
    I was going to try adding color at first, and then decided against it. I then decided on using the pre-stain and natural stain in an effort to help "pop" the grain. These were not top rated pieces of veneer, but were the best I could afford for the project. I would say the grain was just a little muted compared to other examples I have seen.
    Now, in retrospect, I know I should have maybe asked some more questions. Though I am just a poor home hobbyist with little access to nice equipment such as a sprayer, there may have been a better avenue. Using the products I did, with a light polyurethane, has added a reddish hue. For all I know, this may have been a natural aspect of the veneer and unavoidable, but I was seeking something a bit more on the blonde side.
    That being said, I am in no way disappointed. I still like the panels immensely, and they are a vast improvement over the grey beat up old veneer.
    So they are drying, and I may add another coat or two.
    Meanwhile I have about wrapped up my crossovers, nearly ready for install.
    I still have to drill, add hurricane nuts, make new gaskets, dynamat the drivers, and I think I probably want to re-attach the side panels before I reinstall the drivers and crossovers.
    My plan is to use Loctite PowerGrab, unless there are other suggestions?
    Polk Lsi9
    Keces DA-131 mk.II
    F1nut Posts: 51,766
    No doubt, they look WAY better than the stock ones.
    Power Grab needs one surface to be porous otherwise you'll need to use something else.
  • 11tsteve
    I mistyped... or I should say, mis-identified the product. I have a small consumer sized tube of Loctite PL Premium 3X. I have used the construction adhesives for work related projects, and knowing how they perform, the only concern I would have is the possible need to remove the panels at some future point.
    Polk Lsi9
    Keces DA-131 mk.II
    F1nut Posts: 51,766
    Try clear double sided 3M tape. With that you would be able to remove the panels in the future.
  • 11tsteve
    I took your advise, and I thank you very much. It had crossed my mind to do this, but was not confident with that choice until a more experienced person gave the ok. I bought the heaviest duty, and it seems to be working like a champ. The only downside is the very small gap between the panel and the cab, but it is barely noticeable.
    Just finished them up this morning. The piano black finish is not super great, but I tried to buff it up best as I could.
    Just Got the system changed back around, and I am loving the combo of the upgraded McCormack and Lsi9 together. some pretty sizable caps in the new crossovers, so I imagine between the amp still needing time, and the speakers needing a lot of break in, things will be changing a bit here and there over the next couple of weeks.
    Polk Lsi9
    Keces DA-131 mk.II
  • westmassguy
    westmassguy Posts: 6,850
    Very Nice
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • voltz
    voltz Posts: 5,384
    WOW I like it!
  • vmaxer
    vmaxer Posts: 5,120
    Great job.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • 11tsteve
    Thank you for the kind words.... as with anything, I put a lot of effort into these, but there are still some imperfections.
    Working with burled, raw veneer for my first attempt of not using backed veneer was a lot to bite off. And with the tight cab design, the crossovers were a challenge. The board with the 130uF caps literally has maybe 1-2mm between it and the top of the main crossover.
    But overall, I am very pleased with the results.
    Polk Lsi9
    Keces DA-131 mk.II
  • skrol
    skrol Posts: 3,450
    Let me pick my jaw up off the floor... They are gorgeous!
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • vcwatkins
    vcwatkins Posts: 1,993
    Yep, gorgeous. Congrats!
  • rooftop59
    rooftop59 Posts: 8,121
    those LOOK awesome man. Nice job!
    Now, how do they sound???
    Game Room 5.1.4:
    Bedroom 2.1
  • 11tsteve
    rooftop59 wrote: »
    Last night, I came home from a hard day, everyone was on a surprise outing, so I had some unexpected speaker time.... with some serious sound pressure. And between the "new" amp and the Lsi9... well... I just couldn't get enough. I was overwhelmed by my happiness at what I heard. Everything I put in sounded more in-the-room than I have ever heard... more weight, more dimension, more air.... incredible height, depth... it's new amp, speakers, and cables, and it is all as one.
    Then this morning I had a little time. I would not think it will ever sound crappy again, but it was quite the transporting experience. Was it morning? Was it mood? Or is it that I am in the middle of break-in?
    This is my fourth set of speakers I have broken down and refurbished as completely as I possibly can, and I know this always happens in the first week or two. So the best I can answer you question is " they are going to sound ****ing awesome, but need a little time".
    Polk Lsi9
    Keces DA-131 mk.II
  • K_M
    K_M Posts: 1,632
    Looks Great!! Love the finish!
  • lightman1
    lightman1 Posts: 10,796
    edited March 2016
    Looks beautiful! Bring em down to the Quads and I'll break em in for ya. ;)
    Enjoy the fruits of your labor.
  • Face
    Face Posts: 14,340
    Nice job!
  • MrBuhl
    MrBuhl Posts: 2,419
    I just saw this, those are stunning. I love maple and the burl is beautiful.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • 11tsteve
    Thanks guys! Couple of months later, everything settled in, and it's all sounding pretty sweet.
    Now it's time to start playing The Cable Game.
    Polk Lsi9
    Keces DA-131 mk.II
