Polk RTI A9 Home Theatre setup - Power Amp Crown XLS 2002 vs Emotiva xpa-2
24
  • JCsound
    JCsound Posts: 29
    Hey everyone. I'm new here in the forum but I have been a Polk Audio owner for 3 years now. I have a pair of RTi A9's and I love those speakers. When I first bought them I was not too happy with their sound until I discovered that I just wasn't feeding them enough power. This speakers will sound 3x better when you power them correctly.
    I'm passively bi-amping them. I'm using a hotrodded Dynaco ST 70 for the top section and a Crown XLS 1500 for the bottom. I have the Crown using the low pass filter, crossed over at 165hz. They sound very very good in my opinion.
    The new Drive core Crown XLS amplifiers are great amps for the money. Highly recommend.
  • mkr252 wrote: »
    1) Do I need a Power amp in the first place??
    Depends on how loud you listen to it and where you cross it over at. Me personally I rarely get above -25 db and cross over at 80 so technically not really if you're the same. Dynamics will be better, especially at higher volumes and lower crossover frequencies with a high current amp though.
    mkr252 wrote: »
    2) If yes, what would you recommend between Crown XLS 2002 vs Emotiva xpa-2 to power the RTI A9s?
    On the crown keep in mind that they have a bit of a higher noise floor as compared to other home amps. They also have a very dry sonic signature that doesn't add anything to the overall sound, just very neutral. Some people don't like that idea. Lower sensitivity speakers aren't as big of a deal on the noise floor though. High sensitivity cinema speakers are a different story. The crown should run cooler than the Emotiva as well.
    mkr252 wrote: »
    3) I was talking to a home theater specialist at local store. He says, If it use a power amplifier to power front speakers, they are going to out power my center channel and I can't hear any dialogues from my center channel when I watch movies . Is that true??
    Your boy is an idiot. :) That's why you can change the gain and the levels. However, ideally you'd be running identical LCR's and run the same amp on all three.
  • MetropolisLake
    MetropolisLake Posts: 128
    edited January 2016
    mkr252 wrote: »
    @fastmatt:
    Crown XLS 2002 has "Selectable input sensitivity; 1.4Vrms and .775Vrms options so that amp can be driven at full power".
    My AVR Marantz 7009 has 1.4 vmrs. Question: Does it mean that my receiver can make the Crown XLS 2002 drive at full power??
    Typically pro amps are 1.4 volts and the consumer stuff is 0.7 something. Most pro amps are set at 1.4 volts and to raise the level to work with consumer gear you have to use a CleanBox Pro. Some work ok without it, like Behringer iNuke. With the XLS you can just change the sensitivity with the press of a button. Problem with this is that the noise floor goes up. Ideally you'd have XLR's at pro levels going into the amp if possible so you can keep the lower sensitivity. But yes, it works fine with RCA cables, I used a 2502 as a sub amp and many many people use these for their highs.
  • BurrInspector
    BurrInspector Posts: 83
    edited January 2016
    My 2cents!
    I came here looking for the best advice I could get thinking its a Polk forum and the guys here will have the experience and will have tested afew options, that was roughly a year ago. Listen to the guys when they recommend amps, they know what they are talking about.
    I came here knowing I would need an amp after I made a decision that could have resulted in some extended time in the dog house :D Talked to the guys and they all shared their experiences with the A9's and few amps.
    I bought myself a Rotel Amp 5x250w to start of with. (currently saving up for the para A21).
    So I had a week before the amp arrived and that gave me a chance to run the A9's off my Denon 4520 avr (2.0 setup). The a9's sounded thin and everytime the volume level went past -25db the highs got fatiguing. Got the Rotel setup a week later and I can tell you that the A9's sounded amazing. The highs tamed down and now I could crank it past the -25db. The mids and highs picked up and now I had chest pounding bass out of the 2.0 setup. (Well close)
    Later I hooked up the other two a9's and the CSI a6 and I was in speaker heaven.
    The 250w amp is great from Rotel but i know the a9's need more (I listen to music in pure direct mode).
    So just my 2cents, please get an amp. Or try it out with your reciever first and see if you like how they sound, you can always pick up an amp later.
    Post edited by BurrInspector on
  • PSOVLSK
    PSOVLSK Posts: 5,390
    Focus less on this:
    mkr252 wrote: »
    Which of the below 3 options work good for my setup (I added option 3 to my above post to make sure that i'm covering all possible scenarios as I'm not sure how important the extra power to the Center Channel is)??
    1) 2 Channel Power Amplifier (Crown XLS 2002 or Emotiva xpa-2) that delivers over 300 watts per channel at 8 ohms to power front 2 speakers OR
    2) 3 Channel Power Amplifier (XPA 3) that delivers 200 watts per channel at 8 ohms to power front 2 speaker and Center Channel.
    3) 2 Channel Power Amplifier that delivers 440 watts per channel at 8 ohms to power front 2 speakers AND a separate Power Amplifier that delivers 215 watts per channel at 8ohms to power my Center Channel.
    And more on this:
    tonyb wrote: »
    There's a reason why Parasound or B&k amps get pushed more than others. They seem to mate well with Polk speakers
    F1nut Posts: 51,805
    PSOVLSK wrote: »
    And more on this:
    tonyb wrote: »
    Damn good advice!
  • gp4jesus
    gp4jesus Posts: 2,019
    edited January 2016
    mkr252 wrote: »
    in the room you described 15 X 25(?) YES!!
    mkr252 wrote: »
    at the risk of a tomato or 2, I'll mention Rotel as merely another choice, but I'm going w/the flow on this one.
    I have yet to get sufficient quality & quantity of time w/music, to properly evaluate SQ of my two 5 channel amps, neither of which have issues driving my LCR.
    mkr252 wrote: »
    3) I was talking to a home theater specialist* at local store. He says, If it use a power amplifier to power front speakers, they are going to out power my center channel and I can't hear any dialogues from my center channel when I watch movies . Is that true??
    Your boy* is an idiot. :) That's why you can change the gain and the levels. However, ideally you'd be running identical LCR's and run the same amp on all three.
    +1! Further, whether you're running a 3 channel for the LCR or a 5 channel for 5.X, I find the LR needs about 5-6dB more than the CC, invalidating the "idiots*" argument. Don't take this as a reason to short change the CC's need for Quality power, however.
    By the same token, as Metro mentioned, your listening tastes* MAY allow for modest power amp(s). As others have made clear I promise you: a robust (quality*) 85-100(+) can sound quite impressive powering all but the most inefficient or difficult loads.
    *there's that word again. Or "it ain't just about the numbers, dude."
    Cheers
    *all connected w/Premiere ICs
  • JCsound
    JCsound Posts: 29
    Biamping your A9's is a great way to get them to the next step. Specially if you can adjust the crossover points on your amp. The XLS 1500 has a low and high pass filters in them that can be adjusted according to your speakers original crossover specs.
    The new XLS models have band pass filters in them now, so technically you could tri-amp your speakers and not have to purchase an external crossover.
    I'm pushing the bottom end on mine with the XLS crossed over at about 160hz close to where the original Polk crossover is "120 Hz". Then I have my tube amp with a high pass filter set to 100hz, the difference is quite significant. The speakers have a cleaner and more punchy sound.
    I have been contemplating removing the original crossovers but haven't got the courage to do that yet.
    Those xls amps are great, if some of you are worried about the amp sound being to cold, using a tube preamp should fix that.
  • gp4jesus wrote: »
    You may prefer that for some reason, or your distances and heights may dictate this, but with identical LCR’s, when something pans across the screen, it’s not supposed to start on one side at the right level, dip 6 db in the middle, then fire back up on the other side. It’s supposed to be identical and seamless, that's the entire point. I've never heard of anybody killing their center that much, if anything they boost it a little. Assuming everybody needs a 6 db cut just isn't reality.
  • gp4jesus
    JCsound wrote: »
    Go for it, dude! At least so just your EXO controls things between the bass & mids. Expect a little more output & control in the lowest 3 octaves, if you follow my in my foot steps.
    I did just a few months after I got my 'A7s. Further, I modded one. Listened for differences between it & the other. Then did the same to the other & haven't looked back! Mods include:
    removed LP filter to the bass drivers & upgraded wire for same to 8 gage
    upgraded wire to 12 gage** between mid/tweet BP & XO;
    same** between XO & mid
    glued damping to speaker baskets & magnets.
    Did similar stuff to my CC & surround speakers too. Time invested, not wasted.
    Note: for whatever reason the 'A7 mid does not have a HP filter, IMHO a "problem" that bi amping corrects. Further the mid & bass drivers share the same closure volume, another problem I plan to correct soon.
    No flame outs (over the wire upgrades) from the peanut gallery please!
    Accept my apologies for thread hijack. Tony
  • gp4jesus
    ... but with identical LCR’s,
    I don't understand what you mean by this phrase. Check my sig.
    ...when something pans across the screen, it’s not supposed to start on one side at the right level, dip 6 db in the middle, then fire back up on the other side. It’s supposed to be identical and seamless, that's the entire point. I've never heard of anybody killing their center that much, if anything they boost* it a little.
    I don't know*, but my ears & the spl meter seem to agree even after my third upgrade the latest a different brand prepro from the previous 2. During viewing I occasionally notch it up or down slightly...
    something for a survey, perhaps.
  • Geoff4rfc
    Geoff4rfc Posts: 2,854
    mkr252 wrote: »
    What is the best place to buy used Power Amps??
    I found one of mine locally off of C.L. still with warranty. It was my 2nd XPA-2
    Most of the advice/suggestions given here are very good.
    The A9's are bright period. Add more power, still bright. When I added the XPA-2, they were less bright. Music was again, very enjoyable.
    If you could power all three, mains and center, good on ya, but if you can't, as some have already said, the mains will not over power the center, the salesman was full of bad information. Especially if your AVR has a calibrating tool, it will make the adjustments to even out the sound between the different powered speakers.
    I have three different power amps, and three different power ratings powering 9 different speakers, and I have a seamless blend of sound.
    Congratulations on your set up. Dig in and have fun!
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • JCsound
    JCsound Posts: 29
    gp4jesus wrote: »
    JCsound wrote: »
    I have just finished doing a few mods to them just last week. Little by little I have turned my A9's into what I believe is a better speaker than what came out of the factory.
    The first mod I did was to apply dampening foam material inside the whole cabinet and the separate enclosure where the mids and tweeter are. That tighten things up, I consider that a must have mod.
    The next mod I did was modifying the crossovers. I left all the capacitor and resistors values the same but upgraded to better made components. I used soniccap capacitors and mills resistors, those mods made the speakers sound a bit cleaner and the bass a bit punchier.
    The next mod I did, was remove the metallic wood screws that hold the speaker in place. I used brass inserts and non metallic screws, that allows me to remove the drivers as many times as I need to and not worry about the wood in the cabinet holding the screws getting weaker. Also it allows me to increase the torque on the screws which I torqued to 8in lbs.
    Now this next mod was the one that made the biggest difference, I removed the original tweeter and installed a vifa dual ring radiator tweeter just like the one used in the LSiM models. That took the speakers another couple of notches up. It was a point of no return mod.
    And lastly I removed the original cheap plastic feet and installed outriggers and spikes. That not only gave the speakers better stability and looks but also somehow a bit of cleaner bass.
    It was been quite interesting seeing what all this mods do to the speakers.
    I might take your advise and remove the LF section of the crossover and see how that sounds. It might be a while tho, since my fiance is starting to get a bit jealous about how much time I'm spending tweaking my sound system.
  • gp4jesus
    To OP et al: sorry for the continued thread hijack
    JCsound wrote: »
    A9's... ...better than new!
    I know this feeling... ...for my all my speakers. I have work remaining - bi/tri amping the most significant for all & isolating the 'A7 mids from the bass drivers
    JCsound wrote: »
    ...apply dampening foam inside* the cabinet*. ...a must mod!
    My "gluing damping." Did you do same to driver baskets* & magnets*? I did this * to my surrounds, one at a time. Then listened w/bass heavy music w/out tweets. Diffs? Lots of non musical sounds from the stocker!
    JCsound wrote: »
    ...the crossovers.
    Did you replace Polk's lousy, 18 ga wire to mids & bass drivers? Worth it! Ignore the naysayers!!
    JCsound wrote: »
    ...next the metallic wood screws that hold the drivers... ...w/brass inserts and non metallic screws...
    Non metallic screws? Please explain
    JCsound wrote: »
    ...allows me to increase the torque on the screws...
    Consider washers and/or a ring between the closure & driver basket*(s) to avoid distorting same*. OTOH torquing all the same is beneficial too.
    JCsound wrote: »
    ...vifa dual ring radiator tweeter just like the LSiM.
    Would you detail what you like over the stocker? Model/or size & place of purchase? Saving same till after bi/triamping. Want to hear general diff with & w/out XO
    JCsound wrote: »
    ...outriggers* and spikes... ...better stability and cleaner bass.
    Works in concert w/the damping & other mechanical mods. That and if the speakers can't [fractionally] budge, that tightens up everything! Please PM or post a pic*.
    JCsound wrote: »
    ...might remove the LF* section of the crossover and see how that sounds.
    I'm not clear what* this is but... passive XO @ 120hz. Crown XO set @ 100hz HP, 160hz LP, ...interesting. Taking the passive filters out of the circuit, regardless of where you set the HP/LP XO can only make you smile just that much more!
    In summary, mechanical mods help most w/imaging & the lower octaves. Vifa & XO parts help most w/imaging & from lower mid frequencies to 20K+!
    Cheers, Tony
    nooshinjohn Posts: 25,932
    JCsound wrote: »
    gp4jesus wrote: »
    JCsound wrote: »
    pics please, and lots of them.
  • JCsound
    JCsound Posts: 29
    Hey jp4jesus, I have not applied any sound dampening to the drivers themselves. I do not have any material readily available for that, what did you use? Dynamat?
    I have not changed the wires from the crossovers to the drivers. Did you used 12 gauge? I was thinking about doing this a few weeks back and using solid core wire. It is not very flexible but it is great for audio in my own opinion. I use RG142 coax wire as speaker wire.
    About the screws....I meant to say "non magnetic" sorry.
    All I can say about the tweeter mod is, that the speakers sounds more musical now. The highs are not as edgy, they are smoother and a bit more refined. Also this tweeter plays up to 40khz. In my own opinion is a well worth it mod. PM me and I'll send you the tweeter info.
    To not further hijack this thread, I have my crown amp set in stereo with the low pass filter set at around 135 Hz. It made a noticeable difference for the better than when I was feeding it the whole signal, and letting the passive crossover in the speaker do all the work. My tube amp is crossed over with a high pass filter at 100hz, if I didn't have my Dynaco ST 70 I probably would purchase 1 or 2 more Crown XLS's and Bi or Tri-amp them.
    JC
  • JCsound
    JCsound Posts: 29
    Here is a link to a video I made. It doesn't sound the same as when they are heard in person but the main sound is there.
    https://youtu.be/_jOea-9BJ_A
  • Geoff4rfc
    JCsound wrote: »
    AMAZING!!!!!! Sounds just like my Dell desk top speakers B)
    Great work man!!! I'd love to be able to hear those in person, VERY intrigued to hear what a dif the tweeters alone made.
    Nice work on the spikes, thanks for the inspiration!
    Set up:
    F1nut Posts: 51,805
    JCsound wrote: »
    Since the parameters of the RTiA9 tweeter are unknown and you didn't change the values on the crossover the odds of that ring tweeter matching the original specs have to be a million to one.
  • JCsound
    JCsound Posts: 29
    JCsound wrote: »
    You are right, I didn't know the parameters of the original A9's tweeter. Those can be found using test equipment "which I don't have" But what I do know is that, it is crossed over at 1800 Hz, plays up to 23khz, and that it is a 4 ohm , 1" tweeter. so, with that in mind I set out to find a tweeter that matched or beat that. I knew that any tweeter I would find would be a gamble to install in the A9's. There were 3 possibilities 1. It would sound horrible, 2. It would sound the same "very unlikely to happen", 3. Sound better that the stock one.
    So, I decided that one that doesn't take a risk won't win anything. With that in mind I found the radiator tweeter, I looked over all of its specs, saw a performance charts and proceded to take a semi-educated gamble. I knew that if the tweeters didn't work I could save them and use them down the road for something else.
    So I ordered them. When I received them, I proceeded to remove the original tweeter and build a temporary rig to hold the new tweeter in. I then listen to the speakers for a while before fully committing to implement the change.
    They sounded better to me that the stock ones, so I moved on to fully gut the original tweeter from its housing and permanently implement the change. I haven't looked back since, it was worth the gamble. Even tho I'm not sure of how things will read now if one was to take measuraments, I know ultimately the important test is how they sound, it doesn't matter how good they test if they sound bad. On the other hand you may have drivers that don't test very well but that will surprise you when you actually listen to them.
    It was very interesting mod, and I have always been curious to see how far this speakers can be taken.
    Jc
  • Inspector 24
    Inspector 24 Posts: 1,308
    Summation: sounds good to you and you're happy with it.
    Took longer than I thought it would for F1nut to poo-poo the tweeter change :p
    While he's not wrong, I bet the new tweeter could be better optimized on a technical level with crossover changes, I've often thought a tweeter upgrade was what the A9's needed most.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    F1nut Posts: 51,805
    JC, thank you for that and you're right, it's about how things sound. If I may suggest, you need to try some different speaker cable. Anyway......
    This is a mod I did on my RTiA7/CSiA6/FXiA6's for much the same reason, the tweeter was too hot. I felt the mod addressed that issue quite nicely. I also replaced the stock driver screws with stainless steel cap screws going into Hurricane nuts. I thought about using brass inserts as it would have been much simplier, but brass strips too easily. For the RTiA7's and Sanus UF30 stands I had custom stainless steel spikes made.
    http://forum.polkaudio.com/discussion/159998/rtia7-and-csia6-crossover-upgrades-a-slightly-different-approach/p1
    To view the photos, click on the shaded gray boxes at the bottom of the pages.
  • JCsound
    JCsound Posts: 29
    Inspector 24, It would be interesting to see if any other tweaks to the crossover would make the radiator tweeter sound better. As of right now I'm very happy with the sound, and if I decide to mess with the crossovers again it will probably be to remove them and go the Tri-amping route.
    F1nut. Interesting to read about your crossover mod, we went the same route for capacitors and resistors. Money well invested in my opinion.
    F1nut Posts: 51,805
    Well, not quite JC. You retained some of the stock caps and used some Daytons along with one Sonicap. I used all Sonicap.
  • gp4jesus
    edited January 2016
    ...I've often thought a tweeter upgrade was what the A9's needed most.
    I'm certain many would agree, both series*, RTi & RTi A, would grossly benefit from a tweeter upgrade.
    * I think all speakers from both series use the same tweeter(?)
  • JCsound
    JCsound Posts: 29
    F1nut, I'm actually using 2 sonicaps per crossover. I used the Dayton for the low end section.
    gp4jesus, I agree with you. I think Polk also agrees with that, that is why they used different tweeters for their flagship line. I think the tweeters in the Rti line are more directed towards the home theater sound, while the dual ring is targeted towards their musical crowd.
  • gp4jesus
    BEAUTIFUL work!! Well thought out.
    This is a mod I did on my RTiA7/CSiA6/FXiA6's for much the same reason, the tweeter was too hot*. I felt the mod** addressed that issue quite nicely.
    You didn't change any values - the component** upgrade** cooled the tweeters' "heat*?"
  • gp4jesus
    edited January 2016
    JC: "...to fully gut* the original tweeter from its housing and permanently implement the change. "
    How tough was that*? I have my eye on several replacements (Vifa & TB) that graph flat & smooth. Further I think won't require many brain cells to install. OTOH you've proven success...
    Also where did you buy those Outriggers? I want to fit them to my 'A7s.
    And...I used an inexpensive foam material (for damping) that comes in 2" wide 25' or 50' rolls. I'll get back to y'all the brand. I'm certain Dynamat does it a bit betta' but fo' mo' $.
    Finally, I upgraded any and all wire inside* that carries midrange w/AR 12 gage; bass drivers w/8 gage. I did not upgrade any wire between XOs & tweeters - I think its adequate (oops?) I immediately noticed fuller male voices (CC) and tighter, "thumpier" drums, etc (LCR)
    * all speakers
    Sub internal wiring still stock, but I've been VERY busy lately.
    Tony
    Post edited by gp4jesus on
  • ken brydson
    ken brydson Posts: 9,005
    JCsound wrote: »
    Rti = Reference Theater Improved
