Can you still connect speakers on Avr with an additional amp?
VanDaMan
in Electronics
I will be using xpa-5 amp with my receiver to hook up my rtia9. Can I still use the speaker connections from my avr to connect more speakers? For example I'm using the front channels and the surround back can I stil add more to that same channel with other speakers? I wanna get pair of rtia7 and connect them also.
Best Answer
Imdaudioguy wrote: »You already have fronts, a center (I presume), and surrounds, and you want to add another pair of towers? Where? What purpose would they serve?
I currently just have the rtia9 right now! I wanna get a pair of the rtia7 for the surround. Can I still hook them up on the front channels on avr since a9 r hooked up to the amp?
You would hook them up on the surrounds speaker out on the AVR2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Answers
No. You should not use the amp's front channels if you are using its front preout. That said, you wouldn't want to connect your surrounds on the front channel anywats as the surround mix would be completely wrong.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
So here the plan. I got a9s now I wanna get polk a7s also. A9 will be hooked on amp and a7s what channel on receiver should I hook those up to? I got 7.1 channel?
Like I said before "You would hook them up on the surrounds speaker out on the AVR"2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Wait a minute if you have a 7.1 receiver and a 5 channel amp, them you need 5-RCA IC's to the Emo then hook all speakers in a 5.1 to Emo amp
Front L
Front R
Center
Rear surround L
Rear surround R2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
+1 to @txcoastal
If/when you get a pair of side surrounds, they can be hooked up directly to the speaker terminals of the Pioneer; in fact you can power those, + a center, + rear surrounds with your AVR, no sweat.
http://audiomilitia.proboards.com/ -
Recommend a brief perusal of the user guide as that will be covered with all kinds of options.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Am i the only one that's confused?
No , the OP is also.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
Some missing info I thinkMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Why towers for surrounds? I realize in large rooms, that might be the only option, so maybe that's it. Get yourself the CSiA6 center.
mdaudioguy wrote: »Why towers for surrounds? I realize in large rooms, that might be the only option, so maybe that's it. Get yourself the CSiA6 center.
Be honest, I was thinking of towers would be better look then two bookshelf speakers. Do towers and bookshelf sound different? I just thought it would look badass with two rtia9 and two rtia7
I've heard that many times, but I don't really get it. Bottom line is, IMO, surround sound was designed, and works best, coming from above the listener's head. Speakers that can be mounted 6' to 7' off the floor create an ideal sound field. Can it also be done with another pair or two of floorstanders? Yes, if you must. And by must I mean, you have a very large great room (open architecture) with absolutely no walls to mount surrounds on.Be honest, I was thinking of towers would be better look then two bookshelf speakers. Do towers and bookshelf sound different? I just thought it would look badass with two rtia9 and two rtia7
Now, a matching tower used as a center channel? That's a different story. Completely badass (and most certainly not a compromise) if you can pull it off! -
Towers have larger cabinet volume, and so are (usually) capable of more bass response; that is not to say bookshelves can't have good bass.mdaudioguy wrote: »Why towers for surrounds? I realize in large rooms, that might be the only option, so maybe that's it. Get yourself the CSiA6 center.
If you have corners behind the listening position where you can fit towers to be used as surrounds, maybe flip them around so the drivers face the corner? That way the sound will reflect back into the room and not be localized. Just something to try,
I have no idea if it will sound better though.
