Rtia9 with avr pioneer elite vsx-42 make it clip?
VanDaMan
VanDaMan Posts: 33
edited January 2016 in Speakers
Hi, just got pair of rtia9 ($799.00CDN at best buy:) so I rushed home and went on eBay and won a pioneer vsx-42 (highest bidder $202.00US)
I have been doing some research, cause I'm new to audio. New hobby for 2016 :) So I'm planning on bi amping with my pioneer avr, this will give me 80watts per channel, that will give me 160watts high/low frequency.
My plans are to get an emotiva xpa-5 in near future, and a new avr with pre outs which my current avr does not have.
So the question is, will the pioneer vsx-42, 80watt per channel be decent enough to power so the rtia9 won't clip or ruin the rtia9?
Thanks for the help, Van
Post edited by VanDaMan on
Best Answer
  • Thorton
    Thorton Posts: 1,324
    Answer ✓
    tonyb wrote: »
    You can....but I wouldn't go crazy on the volume dial. You'll clip it for sure. I might also choose a different amp too with the 9's later on when your ready.
    What he said. Buy an amp. This is from experience with the A9's
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
Answers
    F1nut Posts: 51,763
    No AVR will drive those speakers properly and no AVR can actually bi-amp, so don't even bother.
    No, it won't. Not even close.
    Inherently bright speakers mated with an inherently bright amp is not the best idea.
    Welcome to Club Polk.
    F1nut Posts: 51,763
    Don't worry, TonyB will be along to explain in greater detail. The sun will be up soon, so I need to head to the coffin.
  • Thanks for answering the question.
    tonyb Posts: 33,072
    Ha....What more need be said ?
    Please review all the other A9 threads and how to go about powering them. Seems these speakers as of late everyone is interested in.
    tonyb Posts: 33,072
    Well then I'm appointing you the official Polk responder for all questions about A9's coming out of the North. I'd have you kneel and anoint you on each shoulder with a Salmon, but Canadians on their knees scare me. :)
    It gets a little repetitious ya know. :p
    tonyb Posts: 33,072
    Goes without saying Ken, but sadly still needs repeating.....daily.
    Kinda reminds me back in the day when car speedometers read 160 on the dial. Idiots thought they could bury that puppy and blew up their engines tryin'.
  • So should I run these rtia9 on the pioneer vsx-42 80 watt per channel since it fairly weak, or will it clip? I'm planning on getting the Pioneer Elite VSX 82TXS 7.1 Home Theater Receiver 130 Watts per channel in future with emotiva xpa-5
    tonyb Posts: 33,072
  • Inspector 24
    Inspector 24 Posts: 1,308
    tonyb wrote: »
    And yet nobody wants to give them enough good clean power. COUGH...Parasound 3500... :lol:
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    tonyb Posts: 33,072
    tonyb wrote: »
    Nobody has their own ComEd sub station in their basement to juice up that badboy. ;)
  • Inspector 24
    Valid point. It does get one circuit breaker all to itself. :p
    Up
    Down
    tonyb Posts: 33,072
    LOL....circuit breaker ? I have a better vision of Homer Simpson in a Nuclear power station throwing switches.
    She's a sweet amp though and frankly your price is a steal. Don't know why someone hasn't snatched it from you yet.
  • So I'm planning on buying another AVR. What's receiver would you guy recommend that around $1000 with about 150watt per channel?
  • Inspector 24
    150 will be a little better, but if the Pioneer has pre-outs you can use them to hook up a separate amp that will be a LOT bit better.
    Ah tony, how'd you know I like the Simpsons?
    Up
    Down
    F1nut Posts: 51,763
    I don't think there are any AVR's capable of 150 wpc. Even if there were, it's still not like a 150 wpc stereo amp.
  • Thorton
    Van,
    As you’ve mentioned, your Pioneer vsx-42 does not have pre-outs. So you cannot add an external amp directly to that AVR. The Pioneer Elite VSX 82TXS does have pre-outs so you would be OK adding an amp to it. So you have a few decisions to make. Based on what you’re using you system for, the members here can make suggestions for you.
    Is this for music, HT or both?
    FYI. The A9’s are very good dual HT and Music speakers and really shine with a high current amp providing clean power. Congratulations, you got those at a great price.
    DAC: Bricasti M1SE
  • Both. Hey is it possible to use the subwoofer preout on my AVR to power the emotiva xpa-2 then hook towers up bridged and hook my towers up in series or parallel to the mono channel?
    Thanks for the help guy :) this my first system
  • No, the sub-out of the receiver is really intended to provide a bass signal to a self-powered subwoofer. If your receiver doesn't have normal right and left preamp outputs the only way to add an amplifier would be to use a speaker level to line level adaptor such as:
    http://www.smarthome.com/xantech-sllc1-speaker-level-to-line-level-converter.html
    This would connect to the receiver's front right and left outputs and then give connections to the inputs of an amplifier.
  • Thanks Ken. Now I don't need a new receiver
  • Good, I'm glad the information was helpful.
  • Ken I took back the thanks and gave it to NB
  • I honestly don't believe it would be a problem. The converter is reducing the voltage from the receiver to a much lower voltage to be able to provide 1 or 2 volts for the required input sensitivity of a power amp. The receiver won't be required to develop anywhere near 35watts in order to do this.
  • I have pioneer vsx-42 80 watts per channel. Don't have preout that's why I wanted try the sub pre-out that it has.
  • That would only give you low bass sounds, not right and left full range sounds.
