MIT Shotgun Z trap ac conditioner thoughts?
polkfarmboy
I was wondering if any of you guys have used one and what you thought about them.
I noticed a slight difference when I have the compact florescent bulbs in on the tube preamp. When I am running the ss pre, I dont hear a difference.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I ended up ordering a couple of these, I am gona try to see if they a difference with wireworld silver electra ac cords. In theory it should give some improvement from having a high end ac cable plugged in to a crappy wired wall plug to having the cable running from the shotgun ac conditioner to the component?
These seem like a good deal and I'm interested in your findings. I use a Nordost q base, with a Nordost blue heaven power cord in my 2 channel system. It works well, but I would Like to lower the noise floor a little more. One of these installed inline with the q base is a good idea for the money.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
i use some earlier version of these with great effect.
http://www.alanmaherdesigns.net/#!product/prd12/4110094531/tech-ground-miniAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Very cool, thank for the link.2 channel:
Theater:
