MIT Shotgun Z trap ac conditioner thoughts?
I was wondering if any of you guys have used one and what you thought about them.
  • erniejade
    erniejade Posts: 6,321
    I noticed a slight difference when I have the compact florescent bulbs in on the tube preamp. When I am running the ss pre, I dont hear a difference.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I ended up ordering a couple of these, I am gona try to see if they a difference with wireworld silver electra ac cords. In theory it should give some improvement from having a high end ac cable plugged in to a crappy wired wall plug to having the cable running from the shotgun ac conditioner to the component?
  • mikeyb128
    mikeyb128 Posts: 2,885
    These seem like a good deal and I'm interested in your findings. I use a Nordost q base, with a Nordost blue heaven power cord in my 2 channel system. It works well, but I would Like to lower the noise floor a little more. One of these installed inline with the q base is a good idea for the money.
    2 channel:
    Theater:
  • marvda1
    marvda1 Posts: 4,951
    i use some earlier version of these with great effect.
    http://www.alanmaherdesigns.net/#!product/prd12/4110094531/tech-ground-mini
    Puritan PSM156
  • mikeyb128
    marvda1 wrote: »
    Very cool, thank for the link.
    2 channel:
    Theater:
