Center speaker match for LSi9
I bought 4 x LSi9 and 1 x LSiC for my surround system and couldn't be happier. Now I am into a new home and the layout doesn't allow me to use the LSiC. I have a wall mounted LCD and there is not enough depth to make a hole in the wall to put the LSiC (the LSiC is 9" deep). I do not want to get rid of the LSi9s as they are wonderful speakers with great imaging.
What do you suggest to use as center channel to match timbre and all the other stuff you guys typically recommend matching?. Does any Polk sound bar would work? Is there any other channel less "deep" that Ic could use? (By the way I already have a sub).
Looking forward to your comments.
Alex
Fronts: 2xLSi9
Center: 1x LSi9
Rear: 1xLSi7 + 1xLSi9
A/V: NAD T753
Sub: Velodyne DEQ-12R
BlueJean Cables
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited December 2015
    Tough one, the LSIc is already fairly shallow compared to other centers. Size it up against a CSiA6 for instance...
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Conradicles
    Conradicles Posts: 6,343
    Polk makes an inwall center with the ring radiator tweeter I think.
    tonyb Posts: 33,072
    Not so sure those small centers will do the accompanying LSI9's justice. If I was the OP, I'd try going no center first and see how I liked it.
    Just make sure you adjust the settings in the receiver to accommodate that.
  • Thanks for the comments. I reviewed several forum posts about "no center" vs "yes center" speaker and I still believe that despite the great imaging of the LSi9s, a center speaker for voice is a must.
    Fronts: 2xLSi9
    Center: 1x LSi9
    A/V: NAD T753
    BlueJean Cables
  • WLDock
    WLDock Posts: 3,073
    Then that LSi voice matched 255c-LS is your only hope. It will be interesting to see how it works out.....it looks like they all have 5-1/4" woofers....so no mismatch there.
    255c-LS - http://www.amazon.com/gp/offer-listing/B004TBKAUG/ref=dp_olp_new?ie=UTF8&condition=new
    http://losangeles.craigslist.org/lac/ele/5369187076.html
    Efficiency 91 dB
    Lower -3dB Limit 44 Hz
    Electrical - Upper -3dB Limit 29 kHz
    Total Frequency Response 30Hz-33kHz
    Nominal Impedance 8 ohms
    LSiC
    Efficiency 88 dB
    Lower -3dB Limit - 52Hz dB
    Upper -3dB Limit - 26kHz dB
    Overall Frequency Response: 40Hz - 27kHz
    Nominal Impedance 4 ohms
    LSi9
    Efficiency 88dB
    Lower -3dB Limits 50Hz - 26kHz
    Frequency Response: Overall / 38Hz - 27kHz /
    Nominal Impedance 4 Ohms
