A year in the making of...
After acquiring my first set of SDASRS, I wanted another set as they are awesome to listen too but more importantly, I have 2 kids and I wanted to give each a set that I had enjoyed over the years. The first step was crossovers and then I acquired some plates frome Trey but I wanted something like the original design but updated.
Fortunately, this time last year, I was talking to my neighbors son and he showed me a piston cup he made from aluminum. I liked it and immediately asked if he could make me speaker plates. I provided the plate from a speaker and let him take it with him. I was a bit nervous giving it to him as a month down the road he didn't recall me giving it to him. Turns out he forgot it at home and all was good. It wasn't long and he had a sample plate. It was a good plate but some of the details I explained to him must have been forgotten somewhere between girls and beers. I wish I could have been there to help him and answers questions because he wouldn't check in with me, and this could have shortened the time. I also provided him text messages to confirm my details of plates, engraving, layout, but he must have not used them as notes. It was a struggle to get him to respond and I almost gave up about 2 months ago.
Well, I got them 2 weeks ago and spent a day and a half sanding and enlarging the holes for binding posts. I then thought about painting them black but the engraving wasn't very deep so I polished them a bit and colored the engraving. I did these for my 3 SDA speakers as I think those are worth the time and money spent for many years to come. I do have a few more Polk speakers but I may or may not do the plates on them. It was a challenge getting these but the best part is that the hard part is finished as he has the program saved and he still owes me a few more plates. Take a look and I hope you like them as much as I do!
First plate. On this one he forgot that I wanted to change the interconnect cable and didnt use the new size.
A pic of plate w Cardas single binding post insulator.
The final product from him. Nicely machined parts.
Sanded and burrs removed w holes enlarged.
Backside of plate where NL4 connector pops in very snug.
Oil paint added to engraving.
All finished!
    nooshinjohn Posts: 25,984
    How much for a set of these for my SDA 1.2tl's.... I NEED a set of these!
  • nikonik
    nikonik Posts: 120
    Nice!
    Thanks Ken. I dig your avatar.
  • nikonik
    nikonik Posts: 120
    How thick is your wallet? JK! At moment, I can't say as it could be a while before I see my other sets. Perhaps I should throw more money at him to entice him to work faster.
  • Nightfall
    Nightfall Posts: 10,083
    There's probably several people here that would be interested...
    afterburnt wrote: »
    Village Idiot of Club Polk
    SCompRacer Posts: 9,121
    Nice work! High marks!
    Nightfall wrote: »
    These could become as popular as Larry's rings.
    F1nut Posts: 51,945
    Nice!
    How did you attach the SpeakOn socket?
    That looks like it was a lot of work. Sanded by hand, machine? Why didn't he punch the binding post holes through?
  • westmassguy
    westmassguy Posts: 6,850
    Those are beautiful
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • nikonik
    nikonik Posts: 120
    Nice!
    It snaps in and hopefully glue will hold them in better. I have tried the male connector and it's all good. It could be drilled and attached better or tapped part way and bolted. Time will tell.
    This is where he didn't hear or listen what I was requesting but it will be done all the way through on future sets. At one point he lost the insulator and I sent him another one. Bumps in the road but the journey was worth it.
    F1nut Posts: 51,945
    edited December 2015
    Well, I like the clean look from the rear mounting, but for me, it would need to be screwed in place. There's no way glue would hold with the cable I use.
    Was all that sanding done by hand or machine?
  • nikonik
    nikonik Posts: 120
    A little bit of both. I used an attachment w drill on center and bench sander on outer ridge. In between the ridge and center, it was by hand. My hands were very busy as I wanted to complete them and ship them to Trey so he can wire them up for me. What I want to do on the next sets was to make the center thicker so the edge of the NL4 connector is flush with the back. This would eliminate fall out as the connector would have to be pulled out straight and not down. They are on snug and with the cables Trey provides, it should be just fine as the weight of cable is on the front side. Now if your talking about the cables that are connected to the backside of the NL4 connector, well then that may be different but a simple fix.
    Im thinking on putting the connector in this direction as it allows for easier removal. The other way is a bit difficult with the clearance.
    Less space for big fingers and I have medium fingers and it can still be difficult to remove cable.
    F1nut Posts: 51,945
    Ah yes, I see the problem. With the body of the SpeakOn mounted to the face that is not an issue. Actually, that's the way it was designed to be mounted.
    As for the press fit.....my thought is it's going to fall out sooner or later, but what do I know.
    They are beautiful and I would be interested in a pair, maybe two.
    msg Posts: 10,458
    Very nice! And doubly cool to heirloom SDA's
    Which binding posts are those? Cardas?
    Also interested if your source becomes open to orders
  • nikonik
    nikonik Posts: 120
    Thanks Jesse! I'll let you know.
  • nikonik
    nikonik Posts: 120
    msg wrote: »
    The kids are 8 n 11 and I hope they are in awe when I show them what will be theirs someday. As soon as I can get more, I'll let you know as well.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Damn man, those are pretty, very classy signature "finishing touch"to the SDA's.
    Shame their location is on the back!
  • DollarDave
    DollarDave Posts: 2,575
    Pop rivets might work well to hold the speakon.
    I'm in for at least one set if they become available. Maybe three.
  • indyhawg
    indyhawg Posts: 1,673
    Very nice work.
  • nikonik
    nikonik Posts: 120
    Many thanks to all of you that like them. I am working on getting the program and looking to find a shop to crank them out as I may be waiting and waiting for him to make them on his spare time. It may take a while just to get the program or get him to make them but I hope to get more made. I think he will be home next week and I plan on working with him to make this happen. Cheers!
  • If your interested and he can't come through on production you can contact me via pm and I'll get you my phone number. I have access to several CNC machines and we can discuss pricing, options etc. if the program is already written, this may something I could start running fairly quick.
  • nikonik
    nikonik Posts: 120
    mopar paul wrote: »
    I like options. I also contacted a local place here but they also need the program. I will keep you in mind and thanks for offering.
  • polrbehr
    polrbehr Posts: 2,847
    Just when I thought there really weren't any more mods to be done to SDAs... LOL
    They are amazing looking.
  • nikonik
    nikonik Posts: 120
    polrbehr wrote: »
    Thank you! I wanted a recessed plate so the connections didn't stick out as far w a flat plate. I hope to get some done so those that want a set, can get a set.
  • MrBuhl
    MrBuhl Posts: 2,419
    man those are really sweet looking. I'd be interested too probably.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • nikonik
    nikonik Posts: 120
    I just got these a few days ago from Trey and when I get time, I will begin to swap out some parts along with changing out crossovers. In addition, I inquired on having 10 sets made and this time he would like to have initial cut done by water jetting vs milling it down and then he can set the circle into the machine and watch it cut. The cost per set would be $145 shipped. For some it may a bit much but for others, it's probably fair. I don't want to take on the entire expense after having spent plenty on the initial sets, binding posts, and 2 sets of crossovers. I am ready to put the spending to a rest and so is my wife. If there is enough interests, I can pursue having more made and in the meantime, I will ask for higher quantity discount but I had to start somewhere. The water jetting does add more cost to the plates vs him cutting them out but it's only a few dollars more having them precut from material supplier. When he did my initial plates, I received a better deal as he used left over material, and part of the reason why it took him longer to make but less expensive. He made 1 set from 7075 and the others from 6061. If he makes more, they would be 6061 as 7075 material will cost about 3-4 times the cost of 6061. He also stated there is a set up fee on top of the cost of material. I thought I had paid for the set up from the previous run but that was the programming and the machines have to be set up. The plate on the left is 7075 and the others are 6061. I personally like the 7075 better but cost is too much. If this doesn't go anywhere, it was fun and exciting to share this project with fellow enthusiasts that find Polk Audio speakers to be the One.
  • ledhed
    ledhed Posts: 1,088
    Very cool!
    I love that you want to pass a set down - a good friend of mine's father did just this for each of his children.
    Even though Paul wasn't into audio before, he is now and the respect he has for his gear is huge - he truly treasures it (though it'd be hard not to treasure Martin Logans driven by McIntosh tubes...).
    Your kids better have some big houses for these beasts!
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • Those are beautiful. I like those a lot. I like the added touch of the paint in the engravings to make them stand out.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • nikonik
    nikonik Posts: 120
    ledhed wrote: »
    Very cool!
    It has been many years since I have heard Mcintosh amps connected to ML speakers. I would drive to Magnolia HiFi in Bellevue, WA and just be in awe at the size of Mcintosh amps and the cable that was coming out of them. It was about 1" thick or more. Very stunning and I was very young with nothing but dreams!
