My ''Cheap'' Speaker Stands 2
pumpkinman
After a few PM's with F1 Nut I've decided to build a set of mass loaded stands. Here's is most of what I need except for some scrap plywood and the play sand which I have in the garage already. More pics to follow.
Because I am The Pumpkinking
Been waiting 2 1/2 hours now. Stop lolly gagging and get to it. You're wasting daylight trooper.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
1/2'' plywood sandwiched together. Needs to be cut to size when glue is set.
Tops are cut to size and run thru the router.
Drilling 1/2'' holes recessed 1/16'' for vinyl bumpers so the speakers stay in place.
Bottoms cut to size and run thru the router.
Installing T-nuts on bottom for whatever. No decision made yet.
o.k. The man has tools.
I still need to drill and countersink for the 3/8'' all thread and use 180 grit wet/dry sand paper to take the shine off of the PVC tubes. Once that's done it's time to paint. I'm fortune-it to have such a warm day in December here in the Pocono's.
Looking good P-man!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Kewl! Nice DIY effort!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
That's some serious Pumpkin Magic!Home Theater/2 Channel:
dhsspeakerservice.com/ -
Very nice!
Dark metallic copper and hammered black
I still need to dry the sand and cut the rods to length.
That's all boys and girls
tip'O cap to the PMan!
Very niceHome Theater/2 Channel:
Sweet.... very nice
ooh, those are clever. What sort of product/material is the upright?
BTW, I really like this observation in the original post:
Sort of sounds like something Yukon Cornelius would have said ;- )pumpkinman wrote: ».... Here's is most of what I need except for some scrap plywood and the play sand...
@mhardy6647
4 in. x 4 in. x 39 in. Vinyl Post Sleeve. 14.47 each
http://www.homedepot.com/p/RDI-4-in-x-4-in-x-39-in-Vinyl-Post-Sleeve-Bagged-61109087/203896281
You are the man my friend, those look great and I can't wait to see the end result!
Would you be interested in making a pair to sell for a profit? I need a pair for my surrounds in my loft, about 28" tall. Just wondering...
I would be curious also... need a pair for my 703s
