Will a CSI-A6 center work with SDA-1C's?
Recently purchased a sealed box of SDA 1C's. They are replacing my RTI-A9's. Power wise, I have Emotiva's reference series XPR-2 and my receiver is the Onkyo Tx-NR5007. I plan to listen to music in two channel stereo mode but am hoping for movies, the CSI-A6 will work out ok with the SDA-1C's. By the way, my subwoofer is the Polk Micro-Pro 4000.
Upstairs Music-HT room
Sony-XBR-75X850C 75 inch 4K TV
Emotiva XPR-2 Power Amp
Onkyo TX-NR5007 Receiver
Integra DPS 10-5 DVD/SACD Player
Mains: Polk SDA 1C Studios
Surrounds: Polk M5 Monitors
Center: CSIA6
Subwoofer: MicoPro 4000
Apple TV
DirecTV
Also have a Dedicated Home Theater Room: see Bryan's Home Theater on YouTube
  • honestaquarian
    The CS-400 or 400i might be a better match.I used one with my SDA-1C's quite successfully. Polk told me to get it.
  • honestaquarian
    The A6 WILL work however.They're just different vintages and different sonic characteristics from different times.
  • ken brydson
    ken brydson Posts: 9,107
    CS350LS works well too if you want to stay vintage...
  • RandyCroissant
    I found a nice CS350LS to use with my 2bs they sound great together. Prior to the CS350 I was using a CS10 bad combo there.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • honestaquarian
    Golfing I cannot recommend replacing the SL-2000 tweeters with some silk dome RD-0194's highly enough!! They are an order of magnitude better.Call Polk and tell them you are a forum member and you will get a discount.
    I did it with my 1C's and also with my Monitor 5jr's.They eliminated a midrange coloration I was hearing with the 5JR's mounted high up on the side walls believe it or not.
    Now that I have the SDA-SRS 3.1TL's, I replaced the SL-3000's with the RD-0198 tweeters.
    My 1C's are up for sale now after 20 years of happy times (*sniff*)
