Using my B&K AV5000 for two channel duty?
Dabutcher
Changing living room set up from five channel to two channel only. Living room is rather small- 12' x12'. I have many pairs to choose from for speakers til I upgrade. Rti 12, Monitor 70, Monitor 10 , Monitor 7, or SDA2a. Marantz SR6001 with pre outs . How can I hook up my five channel amp to two speakers? If this is not a good ldea? I have a few other dedicated two channel amps .i could sell the AV5000 because it is not a good fit in main HT 7.1 system. As always, thanks for any help. Merry Christmas. Peace. D
What other choices do you have? As avr's go I respect the B&K brand, having said that, a dedicated 2 channel amp would be better ( all things being equal ) but hook it up to the front mains and set it up in 2 channel stereo and see if it is satisfing to you. A B&K 2 channel amp of the same power would be a better choice imho.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Just because it's a 5 channel amp doesn't mean you have to use all 5 channels.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I already have the B&K and thought since I am not using it in the 7.1 HT setup . I could run two channels of the five @ 105 w to the top two terminals on M70's and run two to the bottom two terminals. I just do not know if this is beneficial or how to run the IC 's from four connections on Marantz pre to four on B&K? Thanks. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
I already have the B&K and thought since I am not using it in the 7.1 HT setup . I could run two channels of the five @ 105 w to the top two terminals on M70's and run two to the bottom two terminals. I just do not know if this is beneficial or how to run the IC 's from four connections on Marantz pre to four on B&K? Thanks. DI already have the B&K and thought since I am not using it in the 7.1 HT setup . I could run two channels of the five @ 105 w to the top two terminals on M70's and run two to the bottom two terminals. I just do not know if this is beneficial or how to run the IC 's from four connections on Marantz pre to four on B&K? Thanks. D
You need signal splitters to do that for each channel, and extra rca cables.
Beneficial ?? Only one way to find out.
Once you start adding in the costs of the extra cabling, IMHO it would be better to sell it and snag a 2 channel B&k in the 200 watts per range.HT SYSTEM-
lsi 9's -
Have you tried running it straight into your M70s, without bi-wiring?
He wants to bi-amp, not bi-wire, 2 separate things.HT SYSTEM-
